Devo 8 and 2048 resolution
- beemer
27 May 2014 12:42 - 27 May 2014 12:49 #23674
by beemer
Devo 8 and 2048 resolution was created by beemer
Does the Devo 8 support 2048 resolution?
I've searched and have not found any confirmation on this. I know the 802 rx will switch between 11ms and 22ms but this is the frame rate not the resolution, they are two diffrent things.
I found using the search engine DSM2 2048 but I'm currently interested in the Devo line because I have all Walkera hardware at the moment.
Any help would be great
beemer
beemer
Last edit: 27 May 2014 12:49 by beemer.
27 May 2014 13:22 #23677
Replied by PhracturedBlue on topic Devo 8 and 2048 resolution
The Devo protocol is +/-1600 steps (3200 steps in total)for -100 to 100 range. If you go to 150%, you can get a full 4096 steps (0-150% is ~ 2048 steps). This is regardless of the servo frame rate. This is comparable to DSMX which is also 0-150%=2048 steps.
- beemer
27 May 2014 13:37 #23678
by beemer
Replied by beemer on topic Devo 8 and 2048 resolution
So if I understand you correctly the TX and RX both support 2048?
I know other brands can be RX dependent.
Is 2048 active all the time or does it need to be turned on?
I have a few Hitec high resolution servos in a 50cc plane I'm trying to smooth out. They can be "choppy" for lack of a better term, when using long arms and 5 inch wide control surfaces.
Thanks for the help so far
27 May 2014 13:47 #23679
I have no idea how the Rx controls the servos. But the data sent from the transmitter has the resolution I specified. Receivers could choose not to pass that on to the servos, but I'm not sure why they would do that. Note that DSM2 has 1/2 the resolution of DSMX so that wouldn't be a preferred protocol if this matters to you.
- beemer
27 May 2014 13:55 #23680
by beemer
OK great you've cleared up some of my questions (send me the bill).
I might try a DSMX rx, would you happen to know which one would support high resolution?
Time to create page: 0.027 seconds
- Devo 8 and 2048 resolution
