Advance Mode Setup
03 Jun 2014 17:33 #23881 by Torch
Advance Mode Setup was created by Torch
Trying to figure on how to set my Throttle/Pitch Curve and DR/Expo using Advanced Mode instead of modifying model.ini? I can go with Standard mode I know how, but I am trying to modify existing sample model from Tom Z and if I change to Standard all settings would be lose. When I tried to create new model error when config throttle curve.
Trying to setup scale pitch curve and throttle curve.
Throttle Curve = 0,40,80,80,80 and 100 Flat curve for idle up.
Pitch Curve = -3,5,10
Trying to understand Advance mode. You have channel and switch.
04 Jun 2014 18:46 #23909 by Torch
Replied by Torch on topic Advance Mode Setup
I can skip Advance mix for now. Reading the forum found Tom's Devo 7E Standard mix model.
Time to create page: 0.033 seconds
