tx.ini file from DeviationTX on Devo 8s
15 Jun 2014 22:40 #24100 by Hotbread
tx.ini file from DeviationTX on Devo 8s was created by Hotbread
Hi guys,
I'm trying to figure out why DeviationTX on my Devo 8S is not calibrated correctly.
On the model configuration screen (Mixer screen seen in attached image) where you modify the channels, I can't tap the bottom left most button.("Ch8" in the screenshot)
If you have a Devo 8S and running DeviationTX v 4.0.1, can you please post the tx.ini file on your TX?(assuming your TX is calibrated and is working properly) It's the file that contains the touch screen calibration values. It seems mine is off by 10-20 pixels to the top, so I can't hit things on the lower left.(or touch sensitive things are just offset from what they appear.)
PS: I've reported the bug here: bitbucket.org/PhracturedBlue/deviation/i...tion-error-incorrect
However, I would hope to use someone's properly calibrated values so I can continue to use DeviationTX on my own Devo 8S.
