FAIL-SAFE and Safe Value
27 Jun 2014 12:45 #24271 by Torch
FAIL-SAFE and Safe Value was created by Torch
Please explain Fail-Safe and Safe Value. I like to setup my aircraft to automatically shutsdown or throttle down to -100, when binding or transmitter signal is lose. In my case with Blade 200 QX to automatically shut the motor.
So where do I go for settings? I see there is a Fail-Safe optios on each channel and Safe Value. What should these be? I assume we will enable the Fail-safe and set Safe Value to -150?
Reason is I had terrible experienecelast night. Using mod 350qx.ini on Blade 200 QX, I could not get motor to start. Finally I use Rudder d/r(throttle hold) switch somehow got motor to start, but then it won't stop!!
After like two minutes with motor spinning, nothing on TX works to stop the motor, I had to use a pillow to hit one of the blades causing Quad to flash and shutdown.
Time to create page: 0.176 seconds
