I can't Bind a CP Super on Devo 7E with 4.01
06 Jul 2014 17:27 #24429 by pauljohnson
Hi All,
I've just joined this forum.
So Hello to All.
This morning I upgraded my 7E to 4.01 firmware. All went fine until I came to bind the the CP.
The led just flashes fast, I entered the bind in the radio and it counts down but the CP doesn't see it.
So I installed the bind plug in the CP this slowed down the led.
So I tried again to bind with no success... I removed the bind plug and the led flashes fast again, I tried to bind again but just doesn't work.
So I thought I would try it on a Spektrum AR6100 rx, it bound straight away.
I have upgraded to the latest nightly builds 01 July 14 but it's still the same.
Can any body help me, has any body had the same problem?
Kind Regards,
Paul.
06 Jul 2014 17:55 #24431 by FDR
Tbe binding procedure of a DEVO heli is different.
The bind plug only clears the fixed id from the rx.
1. clear the fixed id value on the model config page of the tx.
2. turn off both the tx and rx.
3. turn on the tx, and immediately (within about 10s) plug in the rx.
They will auto bind.
Now if you want to assign a fixed id for that rx,
4. set the fixed id value in the tx...
5. ...and press press the bind button beside the fixed id field.
6. turn them off,
now they are bound with fixed id, so you can turn them on in any sequence...
06 Jul 2014 18:08 #24432 by pauljohnson
Replied by pauljohnson on topic I can't Bind a CP Super on Devo 7E with 4.01
Thank You FDR,
I just removed the 123456 code from my TX and power off then on and powered on the CP and it bound straight away.
Thanks again for taking the time to help me.
:P
Time to create page: 0.515 seconds
