7e mod range 1Km
09 Jul 2014 04:13 - 09 Jul 2014 04:32 #24481 by cmpang
7e mod range 1Km was created by cmpang
as noted in following video, the quad started to fly out at 1:00 and reached 1Km at 2:27. After turning the quad around for return trip, the Rx antenna was oriented at the back side of the quad causing intermittent singal lose.
not happy at the current setup and so go ahead to add on a 2.4g power amplifier.
cmPang
ps. you can also get an idea how far 1km looks like. Usual model plane flying is nothing more than 200m. Less than 100m for helis.
Last edit: 09 Jul 2014 04:32 by cmpang.
09 Jul 2014 08:23 #24484 by SadSack
Replied by SadSack on topic 7e mod range 1Km
How lucky are you! Hitting power line and get away with it :-)
Very useful post details on Amp you'll be using would be great.
09 Jul 2014 08:37 #24485 by SeByDocKy
Replied by SeByDocKy on topic 7e mod range 1Km
1 km with DMSX protocol ?
09 Jul 2014 12:22 #24495 by cmpang
Replied by cmpang on topic 7e mod range 1Km
item.taobao.com/item.htm?spm=a1z09.2.9.1...02015&_u=91aitsjddd5
I have installed this 2W wifi amplifier (XQ-02A) in my 7e. It is tiny and best of all, can operate from 5V down to 3.3V. So I can use my 7e's battery (1S) to feed power to it without any mod.
I have compared the output with and without the amplifier with my spectrum analyser and found that it can boost the power by about 8 to 10dB.
while ground check gives promising results by reducing 7e's output to 3mW, I have yet to find a time to perform another long range test to confirm its performance.
cmPang
09 Jul 2014 12:42 #24499 by SadSack
09 Jul 2014 13:20 #24501 by cmpang
Oop... I got it at USD10 from China shops..
09 Jul 2014 14:02 #24502 by SeByDocKy
If one day, the single universal board is available, this tiny booster should be very interesting.
Time to create page: 0.121 seconds
