devo 10 antenna mod
- sbstnp
19 Jul 2014 12:09 #24690
by sbstnp
Devo 10 + 4in1
Spektrum Dx9
FrSky Taranis + TBS Crossfire
devo 10 antenna mod was created by sbstnp
I never liked the too big antenna on my Devo 10 so decided to mod it.
1. Removed the stock antenna (together with the pigtail).
2. Dremel the stub flush with the case. Used the disc perpendicular on the hole after the cut to even the surface a bit.
3. Use a u.FL to SMA pigtail (10cm, the shortest I had)
4. Choose one of the 2dbi, 3dbi or 5dbi antennas I had laying around.
Range even improved a bit, I got 43 paces (~35m) with the 2dbi antenna using a DSMX sat as receiver, at 100uW, horizontal polarization.
Pics:
Pics:
Devo 10 + 4in1
21 Jul 2014 02:01 #24714
Replied by PhracturedBlue on topic devo 10 antenna mod
Just like the new Devo10-White
- sbstnp
21 Jul 2014 03:48 #24716
by sbstnp
Devo 10 + 4in1
Spektrum Dx9
Replied by sbstnp on topic devo 10 antenna mod
Yep!
Devo 10 + 4in1
- vilaca
05 Sep 2015 21:10 #37479
by vilaca
Replied by vilaca on topic devo 10 antenna mod
I like how you did this.
I might copy you since I broke my antenna and walkera is asking for 5 USD for new one plus 28 USD P&P.
However I'm not sure I can pull it off as I don't own a dremel. I'll have to either buy one or come up with a different way to cut the plastic.
The bit that goes inside the Radio, did you screw it to the PCB or solder?
It would be nice to have a selection of antennas to chose from, according to occasion 2db to 7db
- vilaca
05 Sep 2015 21:42 #37481
by vilaca
I'm doing some reading after my post and now have a few questions
What impedance should the replacement antenna have?
Left or Right hand polarization?
- Arakon
06 Sep 2015 08:10 #37488
by Arakon
Replied by Arakon on topic devo 10 antenna mod
Neither. Linear. These are linear antennas, which can be seen from the fact that they're a straight line.
Impendance is 50 Ohms.
- vilaca
06 Sep 2015 13:47 #37495
by vilaca
Thanks.
I'm trying to learn about this topic to make sure I do the right thing.
How did you come up with the value for antenna impedance?
- Arakon
06 Sep 2015 13:49 #37496
by Arakon
50 ohms is standard for these types of antennas and applications.
- vilaca
11 Jun 2016 20:39 #50425
by vilaca
Finally did a variation of this mod using the 3d printed adapter available at
www.thingiverse.com/thing:1150847
I broke the antenna a few months ago and was asked $5.00 + $28.00 ( shipping cost by UPS ) for a replacement so this is much cheaper and more convenient.
Took around 5m to open the TX, replace pigtail and install 3d printed bit.
Time to create page: 0.063 seconds
- devo 10 antenna mod
