Problem restoring stock firmware on DEVO10
- martenz
28 Jul 2014 19:44 #24872
by martenz
Problem restoring stock firmware on DEVO10 was created by martenz
I would like to come back to stock firmware on my DEVO10 radio after have try the deviation 4.01 firmware.I use the devention Upgrade Tools and all work.
When I switch on the radio the word is all understandable and there's no way to restore it. Now I can use only the DEVIATION firmware.
Could someone help me ?
My stock firmware for DEVO10 is v0,8A
regards
Simone
regards
Simone
- aMax
28 Jul 2014 23:01 - 28 Jul 2014 23:04 #24881
by aMax
Replied by aMax on topic Problem restoring stock firmware on DEVO10
Last edit: 28 Jul 2014 23:04 by aMax.
29 Jul 2014 14:58 #24889
Replied by PhracturedBlue on topic Problem restoring stock firmware on DEVO10
Assuming you've done all that, it is possible your radio is coming up in Chinese.
1st you must get through the safety messages. ensure all switches are set to '0', and throttle is down (you may need to pull elevator down if the tx ends up in mode1)
now you need to go and change the language. I think it is the top menu item in the 1st 2 menus, but I'm not 100% sure of that. The Devo10 manual should explain how to change the language.
- martenz
29 Oct 2014 21:38 #26206
by martenz
Replied by martenz on topic Problem restoring stock firmware on DEVO10
No PhracturedBlue is not chinese I'm sure. I can't go back to original firmware I have tried many times also with ST DFUSE. No way. The original firmware was Fw v0.8A.dfu and DEVO-10 Lib v0.2.dfu gave me the right by walkera with e-mail.
- mikemacwillie
01 Nov 2014 17:32 #26252
by mikemacwillie
Replied by mikemacwillie on topic Problem restoring stock firmware on DEVO10
ST DfuSe will not work, you need to use the Walkera tool. Make sure you load both the firmware and the library, and don't use the 'Upload File' button.
- Olli_Pr
11 Mar 2015 16:02 #29568
by Olli_Pr
Replied by Olli_Pr on topic Problem restoring stock firmware on DEVO10
is there any firmware v0.8 for the Devo10 (white) out there?
I don't like to use deviation until I get my backup-firmware v0.8.
Or does somebody know the differences between 0.7 and 0.8 - so just use 0.7 in case..?
Olli
Olli
- Olli_Pr
16 Mar 2015 09:56 - 16 Mar 2015 09:57 #29755
by Olli_Pr
Hi vlad_vy, I've already seen it..thank you!
Last edit: 16 Mar 2015 09:57 by Olli_Pr.
Time to create page: 0.614 seconds
- Problem restoring stock firmware on DEVO10
