Deviation 8s issue
- Birdman
30 Jul 2014 15:27 - 30 Jul 2014 15:52 #24910
by Birdman
Deviation 8s issue was created by Birdman
I thinks i have an issue somewhere.
Just upgraded to latest release. Now i get toggle icons flash on screen when i turn tx on and model loads. Settings are changing themselves. # of mixers scale have changed. Toggle icons turned on.
Tx or Deviation?
Do not trust it any more
TIA
Bm
also rebooted itself one time when i touched screen
Tx or Deviation?
TIA
Bm
Last edit: 30 Jul 2014 15:52 by Birdman.
- sbstnp
30 Jul 2014 17:48 #24915
by sbstnp
Devo 10 + 4in1
Spektrum Dx9
FrSky Taranis + TBS Crossfire
Replied by sbstnp on topic Deviation 8s issue
Did you upgrade the whole filesystem? Just asking.
Devo 10 + 4in1
- Birdman
31 Jul 2014 00:55 #24926
by Birdman
Replied by Birdman on topic Deviation 8s issue
I guess the answer to that is no. I did not do models and tx files. There are a couple of other files i thought i did not have to load, a zip file of some description.
Is there a tutorial or video on upgrading from a previous version?
Bm
Bm
- sbstnp
31 Jul 2014 04:51 - 31 Jul 2014 04:52 #24928
by sbstnp
Devo 10 + 4in1
Spektrum Dx9
Before blaming anything else you should just backup your files, delete what you have and start fresh.
If it works, then you put back your tx files one by one and see which one causes the radio to misbehave.
Give it a go, at least you'll know if it's a setting or the radio itself.
Birdman wrote: I guess the answer to that is no. I did not do models and tx files. There are a couple of other files i thought i did not have to load, a zip file of some description.
Bm
Devo 10 + 4in1
Last edit: 31 Jul 2014 04:52 by sbstnp.
- Birdman
31 Jul 2014 05:52 - 31 Jul 2014 05:53 #24931
by Birdman
Hi, did that, no good.
Not convinced it means its the radio though.
Bm
Bm
Last edit: 31 Jul 2014 05:53 by Birdman.
- Birdman
31 Jul 2014 06:55 #24932
by Birdman
went back to V3.1.0 beta2 and seems to have fixed it.
There is a bug somewhere?
Bm
Bm
- Birdman
31 Jul 2014 07:03 #24933
by Birdman
Very strange stuff going on.
I just loaded a model that i backed up when V4 was loaded. This model screen has 3 toggles on. I'm sure they are the same ones that flashed up on screen when v4 was loaded. No other models show these toggle icons.
What is going on?
Bm
What is going on?
Bm
- Birdman
31 Jul 2014 07:10 - 31 Jul 2014 07:20 #24934
by Birdman
Had a look, the toggles showing are 1 2 and 6 but none are selected. I deleted them, now they are gone but when i turn tx on with this model selected, now toggle icons 3 4 and 5 flash on screen. This does not happen with other models. when v4 was loaded it did, but icons 1 2 and 6.
I am thinking definately a deviation problem.
Bm
Bm
Last edit: 31 Jul 2014 07:20 by Birdman.
- sbstnp
31 Jul 2014 08:55 #24935
by sbstnp
Devo 10 + 4in1
Spektrum Dx9
Attach the model file here. You could also test it in the emulator.
Devo 10 + 4in1
- Birdman
31 Jul 2014 09:34 - 31 Jul 2014 09:38 #24936
by Birdman
I thought i would try using all v3beta files, nothing from v4. All seemed good until i tried to edit trims page, it does not save changes? Did before this all started.
Here is model ini from v4, glider with crow
name6=Model30
mixermode=Advanced
type=plane
[radio]
protocol=PPM
num_channels=9
tx_power=150mW
[protocol_opts]
Center PW=1100
Delta PW=400
Notch PW=400
Frame Size=22500
[channel1]
template=complex
[mixer]
src=!Virt3
dest=Ch1
usetrim=0
[mixer]
src=AIL
dest=Ch1
muxtype=add
curvetype=3point
points=-100,0,60
[mixer]
src=!Ch8
dest=Ch1
switch=AIL DR1
muxtype=add
[mixer]
src=THR
dest=Ch1
switch=GEAR1
usetrim=0
muxtype=add
curvetype=3point
points=0,-25,-50
[channel2]
template=complex
[mixer]
src=ELE
dest=Ch2
[mixer]
src=MIX1
dest=Ch2
switch=MIX1
scalar=15
usetrim=0
muxtype=add
curvetype=fixed
[mixer]
src=MIX2
dest=Ch2
switch=MIX2
scalar=23
usetrim=0
muxtype=add
curvetype=fixed
[mixer]
src=Ch8
dest=Ch2
switch=AIL DR1
usetrim=0
muxtype=add
curvetype=3point
points=-5,0,20
[mixer]
src=RUD
dest=Ch2
switch=ELE DR1
scalar=0
usetrim=0
curvetype=fixed
[mixer]
src=THR
dest=Ch2
switch=GEAR1
usetrim=0
muxtype=add
curvetype=3point
points=0,20,27
[channel3]
scalar=110
scalar-=100
template=complex
[mixer]
src=THR
dest=Ch3
switch=GEAR0
[mixer]
src=GEAR1
dest=Ch3
switch=GEAR1
scalar=-110
curvetype=fixed
[channel4]
template=complex
[mixer]
src=RUD
dest=Ch4
[mixer]
src=AIL
dest=Ch4
switch=RUD DR1
usetrim=0
muxtype=add
curvetype=3point
points=-27,0,35
[channel5]
template=complex
[mixer]
src=AIL
dest=Ch5
curvetype=3point
points=-60,0,100
[mixer]
src=Ch8
dest=Ch5
switch=AIL DR1
usetrim=0
muxtype=add
curvetype=expo
points=0,0
[mixer]
src=THR
dest=Ch5
switch=GEAR1
usetrim=0
muxtype=add
curvetype=3point
points=0,25,50
[mixer]
src=Virt3
dest=Ch5
usetrim=0
muxtype=add
[channel6]
max=100
min=-100
template=complex
[mixer]
src=MIX0
dest=Ch6
switch=MIX0
scalar=0
usetrim=0
[mixer]
src=MIX1
dest=Ch6
switch=MIX1
scalar=-50
usetrim=0
[mixer]
src=MIX2
dest=Ch6
switch=MIX2
scalar=-100
usetrim=0
[mixer]
src=AIL
dest=Ch6
switch=ELE DR1
usetrim=0
curvetype=3point
points=50,0,-30
[mixer]
src=Ch8
dest=Ch6
muxtype=add
[mixer]
src=THR
dest=Ch6
switch=GEAR1
usetrim=0
muxtype=add
curvetype=3point
points=0,-25,-50
[mixer]
src=Ch9
dest=Ch6
usetrim=0
muxtype=add
[channel7]
max=100
min=-100
template=complex
[mixer]
src=MIX0
dest=Ch7
switch=MIX0
scalar=0
usetrim=0
[mixer]
src=MIX1
dest=Ch7
switch=MIX1
scalar=50
usetrim=0
[mixer]
src=MIX2
dest=Ch7
switch=MIX2
usetrim=0
[mixer]
src=AIL
dest=Ch7
switch=ELE DR1
usetrim=0
curvetype=3point
points=30,0,-50
[mixer]
src=!Ch8
dest=Ch7
muxtype=add
[mixer]
src=THR
dest=Ch7
switch=GEAR1
usetrim=0
muxtype=add
curvetype=3point
points=0,25,50
[mixer]
src=Ch9
dest=Ch7
usetrim=0
muxtype=add
[channel8]
max=100
min=-100
scalar-=100
template=simple
[mixer]
src=Ch8
dest=Ch8
scalar=60
[channel9]
template=simple
[mixer]
src=Ch9
dest=Ch9
scalar=60
[channel10]
template=simple
[mixer]
src=Ch10
dest=Ch10
scalar=-10
curvetype=fixed
[virtchan1]
name=Virt1
[virtchan3]
name=AIL.T
template=simple
[mixer]
src=Virt3
dest=Virt3
scalar=0
curvetype=fixed
[virtchan4]
name=Virt4
[trim1]
src=LEFT_V
pos=TRIMLV+
neg=TRIMLV-
value=-100,0,0
[trim2]
src=RIGHT_V
pos=TRIMRV+
neg=TRIMRV-
[trim3]
src=LEFT_H
pos=TRIMLH+
neg=TRIMLH-
[trim4]
src=RIGHT_H
pos=TRIMRH+
neg=TRIMRH-
[trim5]
src=Ch8
pos=TRIM_L+
neg=TRIM_L-
step=3
[trim6]
src=Ch9
pos=TRIM_R+
neg=TRIM_R-
[timer2]
type=countdown
time=10
[datalog]
switch=None
rate=1 sec
[safety]
Auto=min
[gui-320x240]
V-trim=133,75,1
H-trim=6,220,3
V-trim=183,75,2
H-trim=191,220,4
Big-box=9,40,Ch3
Big-box=9,90,Timer1
Small-box=9,150,Timer2
Small-box=9,181,None
Bargraph=205,150,Ch1
Bargraph=235,150,Ch2
Bargraph=265,150,Ch3
Bargraph=295,150,Ch4
Model=206,40Toggle=130,38,1,64,128,None
Toggle=168,38,2,65,129,None
Toggle=147,76,0,66,0,RUD DR
Toggle=147,115,0,67,0,AIL DR
Toggle=147,153,0,68,0,ELE DR
Toggle=147,192,8,71,0,None
quickpage1=Telemetry monitor
name6=Model30
mixermode=Advanced
type=plane
[radio]
protocol=PPM
num_channels=9
tx_power=150mW
[protocol_opts]
Center PW=1100
Delta PW=400
Notch PW=400
Frame Size=22500
[channel1]
template=complex
[mixer]
src=!Virt3
dest=Ch1
usetrim=0
[mixer]
src=AIL
dest=Ch1
muxtype=add
curvetype=3point
points=-100,0,60
[mixer]
src=!Ch8
dest=Ch1
switch=AIL DR1
muxtype=add
[mixer]
src=THR
dest=Ch1
switch=GEAR1
usetrim=0
muxtype=add
curvetype=3point
points=0,-25,-50
[channel2]
template=complex
[mixer]
src=ELE
dest=Ch2
[mixer]
src=MIX1
dest=Ch2
switch=MIX1
scalar=15
usetrim=0
muxtype=add
curvetype=fixed
[mixer]
src=MIX2
dest=Ch2
switch=MIX2
scalar=23
usetrim=0
muxtype=add
curvetype=fixed
[mixer]
src=Ch8
dest=Ch2
switch=AIL DR1
usetrim=0
muxtype=add
curvetype=3point
points=-5,0,20
[mixer]
src=RUD
dest=Ch2
switch=ELE DR1
scalar=0
usetrim=0
curvetype=fixed
[mixer]
src=THR
dest=Ch2
switch=GEAR1
usetrim=0
muxtype=add
curvetype=3point
points=0,20,27
[channel3]
scalar=110
scalar-=100
template=complex
[mixer]
src=THR
dest=Ch3
switch=GEAR0
[mixer]
src=GEAR1
dest=Ch3
switch=GEAR1
scalar=-110
curvetype=fixed
[channel4]
template=complex
[mixer]
src=RUD
dest=Ch4
[mixer]
src=AIL
dest=Ch4
switch=RUD DR1
usetrim=0
muxtype=add
curvetype=3point
points=-27,0,35
[channel5]
template=complex
[mixer]
src=AIL
dest=Ch5
curvetype=3point
points=-60,0,100
[mixer]
src=Ch8
dest=Ch5
switch=AIL DR1
usetrim=0
muxtype=add
curvetype=expo
points=0,0
[mixer]
src=THR
dest=Ch5
switch=GEAR1
usetrim=0
muxtype=add
curvetype=3point
points=0,25,50
[mixer]
src=Virt3
dest=Ch5
usetrim=0
muxtype=add
[channel6]
max=100
min=-100
template=complex
[mixer]
src=MIX0
dest=Ch6
switch=MIX0
scalar=0
usetrim=0
[mixer]
src=MIX1
dest=Ch6
switch=MIX1
scalar=-50
usetrim=0
[mixer]
src=MIX2
dest=Ch6
switch=MIX2
scalar=-100
usetrim=0
[mixer]
src=AIL
dest=Ch6
switch=ELE DR1
usetrim=0
curvetype=3point
points=50,0,-30
[mixer]
src=Ch8
dest=Ch6
muxtype=add
[mixer]
src=THR
dest=Ch6
switch=GEAR1
usetrim=0
muxtype=add
curvetype=3point
points=0,-25,-50
[mixer]
src=Ch9
dest=Ch6
usetrim=0
muxtype=add
[channel7]
max=100
min=-100
template=complex
[mixer]
src=MIX0
dest=Ch7
switch=MIX0
scalar=0
usetrim=0
[mixer]
src=MIX1
dest=Ch7
switch=MIX1
scalar=50
usetrim=0
[mixer]
src=MIX2
dest=Ch7
switch=MIX2
usetrim=0
[mixer]
src=AIL
dest=Ch7
switch=ELE DR1
usetrim=0
curvetype=3point
points=30,0,-50
[mixer]
src=!Ch8
dest=Ch7
muxtype=add
[mixer]
src=THR
dest=Ch7
switch=GEAR1
usetrim=0
muxtype=add
curvetype=3point
points=0,25,50
[mixer]
src=Ch9
dest=Ch7
usetrim=0
muxtype=add
[channel8]
max=100
min=-100
scalar-=100
template=simple
[mixer]
src=Ch8
dest=Ch8
scalar=60
[channel9]
template=simple
[mixer]
src=Ch9
dest=Ch9
scalar=60
[channel10]
template=simple
[mixer]
src=Ch10
dest=Ch10
scalar=-10
curvetype=fixed
[virtchan1]
name=Virt1
[virtchan3]
name=AIL.T
template=simple
[mixer]
src=Virt3
dest=Virt3
scalar=0
curvetype=fixed
[virtchan4]
name=Virt4
[trim1]
src=LEFT_V
pos=TRIMLV+
neg=TRIMLV-
value=-100,0,0
[trim2]
src=RIGHT_V
pos=TRIMRV+
neg=TRIMRV-
[trim3]
src=LEFT_H
pos=TRIMLH+
neg=TRIMLH-
[trim4]
src=RIGHT_H
pos=TRIMRH+
neg=TRIMRH-
[trim5]
src=Ch8
pos=TRIM_L+
neg=TRIM_L-
step=3
[trim6]
src=Ch9
pos=TRIM_R+
neg=TRIM_R-
[timer2]
type=countdown
time=10
[datalog]
switch=None
rate=1 sec
[safety]
Auto=min
[gui-320x240]
V-trim=133,75,1
H-trim=6,220,3
V-trim=183,75,2
H-trim=191,220,4
Big-box=9,40,Ch3
Big-box=9,90,Timer1
Last edit: 31 Jul 2014 09:38 by Birdman.
- Sero
- RC-addicted
09 Aug 2014 20:30 #25116
by Sero
Replied by Sero on topic Deviation 8s issue
The very first line seems to be faulty, is there really a 6 in your file?
- Sero
- RC-addicted
09 Aug 2014 20:40 #25117
by Sero
Plus, toggle 3, 4 and 5 ARE selected to show something, see snippet:
Could you please post the entire file, not just it's contents, as I have seen some strange faults in some lines.
- Birdman
10 Aug 2014 09:11 #25121
by Birdman
You have miss read my post. I did not say 3 4 5 are not selected. It says 1 2 6 have no icon selected, or 1 2 6 are set to NONE.
Thanks anyway.
Bm
Thanks anyway.
Bm
Time to create page: 0.185 seconds
- Deviation 8s issue
