Devo 8s users please.
01 Aug 2014 09:18 #24943 by Birdman
Devo 8s users please. was created by Birdman
I would like to know if anyone out there is using a devo 8s with latest deviation release.
Things are not right with my tx and i believe it is deviation not the tx itself.
If i could correspond with someone i may be able to determine what is going on.
TIA
Bm
01 Aug 2014 09:42 #24944 by Birdman
Replied by Birdman on topic Devo 8s users please.
Eg
In pic below there are no switches showing on right hand side of page, there should be?
When i reorder a channel the column on left should change to suit? If so this does not happen?
The tx servos work and follow mixers etc, just seems like some of the screens are not working correctly.
02 Aug 2014 00:46 #24963 by Birdman
It looks like the what is described above is stopping me setting safety screen.
When i can get it to close with thr, ail goes to full deflection becouse of the conflict.
Bm
02 Aug 2014 10:57 #24965 by Birdman
Guess i'm the only one. Increases the odds of it being deviation.
I can't fix it and i can't stay grounded. Sorry to "sound" impatient but i can't wait around in the hope that someone "might" help.
Time to get that Taranis.
Cheers
Bm
02 Aug 2014 11:18 #24966 by Sero
Replied by Sero on topic Devo 8s users please.
That is the strangest setup that I have ever seen, that may be the reason for the lack of response...
02 Aug 2014 11:19 - 02 Aug 2014 11:20 #24967 by Sero
What mode are you using normally, and which one is set up on the TX?
Last edit: 02 Aug 2014 11:20 by Sero.
02 Aug 2014 13:55 - 02 Aug 2014 13:56 #24971 by Birdman
Thanks for chiming in.
Mode2 and mode2 which is default.
It is not setup. A fresh unused model page has same issues.
I think it is because of upgrading to latest release. If it is deviation there is only a couple of people that can probably help.
I can put of ordering Taranis for 24hrs, but i reckon the devo8 is going in bin.
Time to move on to bigger and better things.
Bm
Last edit: 02 Aug 2014 13:56 by Birdman.
02 Aug 2014 15:26 #24973 by Sero
What protocol are you using, i.e DSM2?
02 Aug 2014 15:29 #24974 by Sero
The reason I ask, if the TX is set to mode 2 and you're using the right protocol, there would be no reason to move throttle to another canal...
02 Aug 2014 16:11 #24975 by Blayd
Replied by Blayd on topic Devo 8s users please.
Hi Birdman.
I use the Devo 8S on 4 heli's.
Not sure whats going on but I would like more info.
Why are you moving the channel? And which protocol are you trying to run? What model are you trying to set up? ( plane? Heli? )
Devo 8S
Trex500ESP
Trex500ESP (Belted tail)
HC500SE
Trex700N2E
02 Aug 2014 18:31 #24981 by FDR
Replied by FDR on topic Devo 8s users please.
The channel names won't change when you move the channels, only their content will move.
Channel names are determined by the protocol...
Don't use the nightly build if you don't trust it: that is the version under development.
Use the v4.0.1, it's quite stable...
03 Aug 2014 08:15 #24988 by Birdman
You could be on to something there. Protocol is DSM2 rx is Spectrum AR7000. But the rx is seeing aileron as ch1, ele2 thr3 rud4. JR Spectrum thr is ch1. It is the tx that determines ch order.
Is tx sending wrong ch order, if so why?
Plane
Not using nightly.
Bm
03 Aug 2014 08:38 - 03 Aug 2014 08:44 #24990 by Birdman
Blayd and Sero is on to it. I feel very much like a dumb ass. Been at it for days and did not pick up on that. When you select DSM2 you have to reorder channels to suit.
Thanks guys.
Last edit: 03 Aug 2014 08:44 by Birdman.
03 Aug 2014 08:40 - 03 Aug 2014 08:48 #24991 by Birdman
Next problem.
When devo splash screen closes toggle icons flash momentarily on screen as model loads?
Is this normal?
Bm
Not an issue that would stop me flying but don't remember this happening before upgrade.
Last edit: 03 Aug 2014 08:48 by Birdman.
03 Aug 2014 08:54 #24992 by Birdman
3rd problem.
On one occasion the tx rebooted when i touched arrow (i think) at top right corner of page.
Bm
03 Aug 2014 10:38 #24993 by Birdman
I will try and explain toggle thing a bit better.
If a toggle is added to screen but no icon is selected, an icon flashes on screen in correct location. If an icon is selected but toggle is off a ? flashes on screen in that toggles location..
Bm
04 Aug 2014 00:44 - 04 Aug 2014 00:46 #25008 by Birdman
What a shame. oh well.
The reboot is to much of a worry, do not trust deviation.
Taranis ordered.
Have fun people.
Bm
Last edit: 04 Aug 2014 00:46 by Birdman.
05 Aug 2014 18:34 #25038 by Îluminatus23
Replied by Îluminatus23 on topic Devo 8s users please.
I also got reboots with my Devo8s.
Thats very very bad, because it caused a bad landing... :(
Here is the protocoll of the error.txt:
[Hard fault]
devo8-v4.0.1
R0 = 00000000
R1 = 00000000
R2 = 08028a0c
R3 = 666f7800
R12 = 00000050
LR [R14] (subroutine call return address) = 08015e07
PC [R15] (program counter) = 666f7800
PSR = 40000000
BFAR = e000ed38
CFSR = 00000100
HFSR = 40000000
DFSR = 00000000
AFSR = 00000000
SCB_SHCSR = 00000000
Top of Stack:2000c000
Stack Detect:2000bf78
Backtrace:
2000bf8c : 08015e07
2000bfa4 : 0801615d
2000bfb4 : 0800a411
2000bfcc : 0800a473
2000bfec : 0800b32b
2000bff4 : 0800b439
Done
Can someone help me???
05 Aug 2014 19:47 - 05 Aug 2014 19:48 #25042 by Blayd
My 8S has never rebooted on the last release. So far. And I fly a 700 heli on this release.
I wish we could also get an error text from Birdman as well.
Devo 8S
Trex500ESP
HC500SE
Trex700N2E
Last edit: 05 Aug 2014 19:48 by Blayd.
06 Aug 2014 05:06 #25057 by Îluminatus23
Thanks for your reply! But what can i learn by this error.Txt?
Time to create page: 0.218 seconds
