Making a servo move to 3 seperate positions. Dvo10
- rcminiman
11 Aug 2014 17:59 #25154
by rcminiman
Making a servo move to 3 seperate positions. Dvo10 was created by rcminiman
I have a Devo 10 running deviation, and am flying a hexacopter for aerial photos using a regular small camera.
I would like to set it up so a servo presses the shutter button half way to focus, just like in real life, then move fully to take the photo.
I want to use the Fmode 3 position switch to do this. Im in the complex mixer, and now am stuck. Amybody help me please?
- sbstnp
11 Aug 2014 19:05 #25156
by sbstnp
Devo 10 + 4in1
Spektrum Dx9
FrSky Taranis + TBS Crossfire
Replied by sbstnp on topic Making a servo move to 3 seperate positions. Dvo10
1. choose a switch (FMODE for example)
2. find scale=? at which you can focus (fmode1)
3. find scale=? at which you can trigger (fmode2)
Can't help with the exact scale, you need to experiment yourself.
Devo 10 + 4in1
- rcminiman
11 Aug 2014 21:19 #25160
by rcminiman
Replied by rcminiman on topic Making a servo move to 3 seperate positions. Dvo10
still totally lost im afraid. I don't have a clue how to do it at all.
1.go into "mixer"
2.go to channel 8. At the moment it says "simple"
Whats next? tried a few things, but can only get 2 positions on the graph when the switch is operated.
1.go into "mixer"
- TomPeer
11 Aug 2014 23:22 - 11 Aug 2014 23:35 #25161
by TomPeer
Replied by TomPeer on topic Making a servo move to 3 seperate positions. Dvo10
Go to the channel you want.
Change simple to complex.
Set mixers to 3
Src to FMODE0
Curve to Fixed
Scale to ?
Then go to page 2
Switch to FMODE1
Src to FMODE1
Curve to Fixed
Scale to ??
Then go to page 3
Switch to FMODE2
Src to FMODE2
Curve to Fixed
Scale to ???
Save.
? ?? and ??? are numbers between -100 to 100. You have to find out yourself. They determen the position of your servo for the 3 positions of the switch.
Good luck
Set mixers to 3
Src to FMODE0
Curve to Fixed
Scale to ?
Then go to page 2
Switch to FMODE1
Src to FMODE1
Curve to Fixed
Scale to ??
Then go to page 3
Switch to FMODE2
Src to FMODE2
Curve to Fixed
Scale to ???
Save.
Good luck
Last edit: 11 Aug 2014 23:35 by TomPeer.
- rcminiman
12 Aug 2014 14:35 #25171
by rcminiman
I tried this briefly before work, and im sure the src changed back to "none" when I changed the curve to "fixed". I didnt get a chance to plug in an rx and try it out for real though.
Thanks, hope it works.
The camera seems to work a lot better when you let it actually focus first on the subject.
12 Aug 2014 14:51 #25173
Replied by mwm on topic Making a servo move to 3 seperate positions. Dvo10
If the curve type is "fixed", the source will always be "none", since it's ignored. You don't need to change the source here.
- TomPeer
12 Aug 2014 15:22 #25176
by TomPeer
oops
sorry about that.
sorry about that.
- rcminiman
12 Aug 2014 18:08 #25179
by rcminiman
YES!! Delighted its now working great, thanks loads guys. Now I just have to wait for the lovely Scottish weather to calm down a wee bit so I can fly. We currently have the remains of Hurricane Bertha stuck overhead and its going nowhere soon.
Cheers all,
Barry
Cheers all,
Barry
Time to create page: 0.497 seconds
- Making a servo move to 3 seperate positions. Dvo10
