DEVO 12E
31 Aug 2014 06:56 #25438 by CookieM
DEVO 12E was created by CookieM
is there already a possibility to use deviation on the 12E? (the white model)
Thank you in advance
O.
10 Oct 2014 08:48 #26024 by Joe6pack
Replied by Joe6pack on topic DEVO 12E
that would interest me too.
I'm about to buy a Devo. Either 10 or 12E.
Runs Deviation on a 12E?
10 Oct 2014 11:05 - 10 Oct 2014 11:05 #26026 by IMback!
Replied by IMback! on topic DEVO 12E
Well I dont think anyone knows, without trying. It very mutch depends on how different the devo 12e is from the devo 10. If they just connected new switches to unused pins on the mcu Then deviation for devo 10 would work, just without the extra switches. If they rearanged the pins or chaned the mcu in any way deviation would not work without modifications/
In any case supporting the devo 12e is likely possible with minnimal effort.
Last edit: 10 Oct 2014 11:05 by IMback!.
21 Nov 2014 16:49 #26485 by CalifGuy
Replied by CalifGuy on topic DEVO 12E
Joe6pack wrote: Hello,
Anyone successfully try this yet? Getting ready to pickup a new radio and the Devo 12E with Deviation would be ideal.
18 Dec 2014 14:46 #27079 by schwarzsurfer
Replied by schwarzsurfer on topic DEVO 12E
is there any chance to get deviation for the 12E? I would love to buy one, but it needs to have deviation. Otherwise I would get a 10.
Is this project still alive? :huh:
Marian
18 Dec 2014 16:54 #27082 by dlawso
Replied by dlawso on topic DEVO 12E
I have a Devo12e, please programiere for this station.
Greetings
Oswald
18 Dec 2014 21:39 #27086 by kreidler
Replied by kreidler on topic DEVO 12E
Oswald,
please open the transmitter and share some internal pictures. Most interesting would be how the pots are connected to the boards.
23 Dec 2014 18:30 #27166 by Emc2
Replied by Emc2 on topic DEVO 12E
Here are the pictures of my DEVO 12E. I hope it will help someone to make firmware for it. :cheer:
23 Dec 2014 18:33 #27167 by Emc2
...more pictures
11 Mar 2015 07:01 #29558 by gektor
Replied by gektor on topic DEVO 12E
Is there any significant difference to Devo 10 at all?
11 Mar 2015 07:38 #29560 by linux-user
Replied by linux-user on topic DEVO 12E
gektor wrote: Is there any significant difference to Devo 10 at all?
The most obvious are the two extra pots
11 Mar 2015 07:43 #29561 by FDR
Replied by FDR on topic DEVO 12E
The two more knobs...
11 Mar 2015 08:02 #29562 by gektor
Yes, it's obvious, LOL :lol:
But besides?
I'm thinking of it from the point of view of deviation portability. They are almost the same, as it seems.
11 Mar 2015 08:48 #29563 by schwarzsurfer
Still waiting so hard for someone to port Deviation for the 12E... Would love to buy that thing :woohoo:
11 Mar 2015 10:55 - 11 Mar 2015 11:01 #29565 by vlad_vy
Replied by vlad_vy on topic DEVO 12E
Both PCB (Devo 10 and Devo 12E) have very similar layout. Added AUX7 and AUX5 connectors and renamed AUX1 to AUX4 and AUX2 to AUX6 connectors. I think will be enought to trace connections for AUX4 - AUX7 to MCU pins (probably center contact only - center output of pot).
Last edit: 11 Mar 2015 11:01 by vlad_vy.
17 Mar 2015 06:39 #29773 by netnerd
Replied by netnerd on topic DEVO 12E
Oh cool, there's people talking here. I was going to make a post quickly but decided to do a search first.
I'm thinking about ordering in a DEVO 12E to run deviation on it and a while ago (didn't have funds at the time) I looked into making the appropriate modifications to the source. Because it's so similar to the DEVO 10, I think that just adding the extra knobs to some target files copied from the DEVO 10 and changing the target name and whatnot was pretty much all I needed to do to get what I felt should work.
Walkera Fans has a copy of the firmware and the crypt for dfu.py appears to be 12, as was to be expected.
If anyone absolutely needs a build, I can try running one off, but it would be untested and it's probably better to let the more skilled people figure it out.
17 Mar 2015 13:51 #29775 by PhracturedBlue
Replied by PhracturedBlue on topic DEVO 12E
I compared the devo12e images to the devo10 images.
It looks like PA0 and PD9 have new connections, and I don't see any other pin changes on the STM32.
PA0 is ADC0, but PD9 is a purely digital pin. So it is possible they swapped some pins around to get usable ADC pins.
17 Mar 2015 14:34 #29777 by netnerd
That makes sense. I did have a look at the pin assignments originally, but I don't do very much electronics work. It was a bit hard to make sense of it all, but I kinda figured that PD9 was effectively doing nothing we can actually see because of a missing jumper, although PA0 is definitely of interest. Is it possible for the to be something hidden underneath the chip?
Anyway, I guess that actual hardware is the only way forwards, huh?
17 Mar 2015 17:02 #29780 by PhracturedBlue
You may be right about PD.9
I think the 2nd analog pin is PB.0.
I will throw together a 12E build. If someone has one to try it, we can see if that is all that is needed
17 Mar 2015 18:42 #29782 by PhracturedBlue
I built a test-build for the devo12e here:
www.deviationtx.com/downloads-new/category/32-test-builds
Once someone tests it, I'll add it to the nightly-build scripts
Time to create page: 0.779 seconds
