Devo 7e with 3x2 switch mod left trim issues
11 Sep 2014 14:00 - 22 Sep 2014 20:28 #25614 by FusionDawg
I've implemented the 3x2 switch mod per www.deviationtx.com/forum/7-development/...tion?start=100#22231
I have also set extra-switches=3x2 in hardware.ini.
I am using the most recent nightly build (v4.0.1-92e1705).
Now, my left trims (both horizontal and vertical) and my Switch A up position does not work.
All connections seems to be good. There is no short that I can see.
Did I fry something while soldering in the wires? Any ideas of what to check?
Is it possible to remap the right trims to adjust the left trims when Switch A is in the down position?
Last edit: 22 Sep 2014 20:28 by FusionDawg.
11 Sep 2014 16:36 #25618 by D_an_W
Did you remember to add the 4 diodes in the correct orientation?
11 Sep 2014 18:00 #25620 by FusionDawg
Replied by FusionDawg on topic Devo 7e with 3x2 switch mod left trim issues
Yes, diodes are installed at all 4 terminals. They are oriented with the stripe closest to the switch. The current flows into the switch as verified by a multi-meter.
22 Sep 2014 20:27 #25768 by FusionDawg
I fixed the issue with the trim.
When I soldered the "brown" wire (the one that connects to the middle pin on the right), I had melted the solder that attaches to the trace on the PCB.
I was able to re-solder making contact with the trace and got it working again.
Time to create page: 0.101 seconds
