Deviation install problem - Devo12S
27 Sep 2014 16:01 - 27 Sep 2014 16:04 #25833 by copter
Deviation install problem - Devo12S was created by copter
I try to install DeviationTX to DEVO12S.
1, firmware
upgrade devo12-v4.0.1 fw.
2, library
devo12-v4.0.1 lib
The upgrade procedure is correct.
Buuut, the dfuse 1.7 sayd: "Your device was plugged in DFU mode. So it is impossible to make sure this file is correct for this device. Continue however?"
After install 2 files, reboot.
The screen is blue, and clear.
I try to down ENT with power on, but no effect.
Now transmitter allways On state. The power switch is no effect,
only the battery remove is good for switch off.
Any idea?
Thank you!
Last edit: 27 Sep 2014 16:04 by copter.
Time to create page: 0.065 seconds
