Layout of ini file /missing CR/LF
- FrankV
12 Oct 2014 08:08 #26046
by FrankV
Layout of ini file /missing CR/LF was created by FrankV
maybe a dump question, but.....
A model file as posted on this site has a layout that is readable.
Once loaded in the Devo10 all "enter/return" is gone from the file, ending up whitch a big bunch of unreadable data.
So befor I would like to edit the values, I have to put a lot of "enters" again..
Might be very simple, but how do you people maintain the layout?
Example: original file (downloaded from this forum)
name=TestName
mixermode=Advanced
type=plane
[radio]
protocol=DSM2
Etc.
This will be changed bu the Devo in the following line (one very long sentence) like this:
name=Sonic64mixermode=Advancedicon=PLANE.BMPtype=plane[radio]protocol=DSM2Etc.
name=TestName
mixermode=Advanced
type=plane
[radio]
protocol=DSM2
Etc.
- aMax
12 Oct 2014 08:36 #26048
by aMax
Replied by aMax on topic Layout of ini file /missing CR/LF
- Daryoon
14 Oct 2014 15:41 #26080
by Daryoon
Replied by Daryoon on topic Layout of ini file /missing CR/LF
Your problem will occur if you use a text editor that does not respect the CR/LF.
e.g. Windows Notepad
Many of us use the free Notepad++ program that is available for free. aMax linked to it above.
On the Mac side, I use TextWrangler. And that seems fine.
- FrankV
19 Oct 2014 10:44 #26110
by FrankV
Replied by FrankV on topic Layout of ini file /missing CR/LF
Thanks for the info.
Installed notepad++ and it works.
Would be easier though to use the notepad from the stoneage, but I'll have to live with this one.
Although there might be an option if editing in Excel or something similar to change parameters, because you have a better overview of the settings. Like the Devo 7 editor (screenshot attached) makes things quite easier.
I think that is not possible?
- marcoose
21 Oct 2014 12:18 #26124
by marcoose
Replied by marcoose on topic Layout of ini file /missing CR/LF
Somebody could certainly design an editor since it is just a plain text file, but I don't believe anybody has bothered to replicate such an editor for PC. You can use the emulator if you want to run the actual TX editor on your PC with the keyboard.
As pointed out by others, Deviation and Unix/Linux systems use a single line feed character to end lines, but Windows uses a carriage return + line feed combo (LF vs CRLF), so because the CR is missing the end-of-line is not interpreted correctly by basic Windows editors. Notepad++, PSPad, UltraEdit, and even Windows WordPad will handle just LF though.
- alibenpeng
27 Oct 2014 14:04 #26179
by alibenpeng
Replied by alibenpeng on topic Layout of ini file /missing CR/LF
I found there is some binary padding (0x00) data at the end of my .ini files. Can I just ignore/remove that or will that make bad things happen?
Time to create page: 0.118 seconds
- Layout of ini file /missing CR/LF
