7e Lost plane, same fate if I use 10?
13 Oct 2014 02:05 #26062 by flyberd
7e Lost plane, same fate if I use 10? was created by flyberd
I got a 7e I was using to test out this program. I lost control of the plane probably 50-75 feet away from me. I ended up losing the plane in soybeans :(. It was a small fox glider with DSM2 Rx. If I put this on my Devo 10 am I destined to the same fate? I really had high hopes for the program now I am scared to try again on my more expensive birds.
13 Oct 2014 06:11 #26064 by SeByDocKy
Replied by SeByDocKy on topic 7e Lost plane, same fate if I use 10?
flyberd wrote: I got a 7e I was using to test out this program. I lost control of the plane probably 50-75 feet away from me. I ended up losing the plane in soybeans :(. It was a small fox glider with DSM2 Rx. If I put this on my Devo 10 am I destined to the same fate? I really had high hopes for the program now I am scared to try again on my more expensive birds.
Without the "diode mod", the 7E have a limited power for DSM2/DMSX protocol. The Devo 10 and > don't have this hardware limitation
13 Oct 2014 10:07 - 13 Oct 2014 10:53 #26066 by aMax
Replied by aMax on topic 7e Lost plane, same fate if I use 10?
Only...75 feet distance? Even without " diode mod" that should not happen.
What RX are you using? Orange RX ? Brownout with a build in mini RX?
What transmission power did you use?
And did point at the model with the TX ( antenna) at that time?
The antenna is the only weak part of that TX, because it could be aligned to its best RF emmision.
Last edit: 13 Oct 2014 10:53 by aMax.
13 Oct 2014 10:32 #26067 by Arakon
Replied by Arakon on topic 7e Lost plane, same fate if I use 10?
I've had my quadcopter with a 7e with the range mod, using an orange DSMX receiver, at 980 ft (at 160 ft height) and also 850 ft height (about 160 ft away from me) without issue.
13 Oct 2014 11:01 - 13 Oct 2014 12:13 #26068 by aMax
But I assume this one is original.
Before I was doing the diode mod, I have tested the 7e with a SuperCP against A7105-D03 and a V911.
Both with were set to minimum transmission power (100 µW)
At 16 meter I lost binding with the SuperCP, holding the TX sideways it rebind immediately.
With the A7105-D03 the direction did not matter at that distance.( build in /antenna 90 degree to front)
EDIT:...sorry guys, looking at my notes, I did the this test after the mod. :oops:
Last edit: 13 Oct 2014 12:13 by aMax.
13 Oct 2014 17:56 #26069 by mikemacwillie
Replied by mikemacwillie on topic 7e Lost plane, same fate if I use 10?
Any chance you had your TX power set really low? 75 feet is really short range, even for an unmodded 7E.
Time to create page: 0.210 seconds
