Dont think my hold switch on devo 7e is working??
- scooterstew
02 Nov 2014 11:17 #26258
by scooterstew
Dont think my hold switch on devo 7e is working?? was created by scooterstew
hi just recently installed the latest nightly build....
got A7105 and nrfl401 modules installed and working great....
but I dont think my hold switch is working at all??
on the channel monitor option the other switch fmod makes the value go to -100 to +100 when switched on and off....
but when I switch the hold switch nothing happens....
when I had just 4.0.1 installed Im sure the hold switch worked.....
any ideas???
how can I test it for sure to find out......
thanks......
any ideas???
thanks......
- Deal57
02 Nov 2014 20:10 #26264
by Deal57
Usually the hold is set up on the throttle channel, not as a separate channel. So the channel monitor should show your throttle channel go to -100. Have you verified that this the behavior using the emulator? If toggling the hold key works (I think it is the z key) in the emulator, you'll see the throttle value to -100. Then if the same model settings don't work on the Devo you'll know you've got a HW problem.
Here is an example from my throttle setting in the ini file.
[Channel 3]
safetysw=HOLD1
safetyval=-100
[mixer]
src=THR
dest=ch3
curvetype=3point
points=-100,60,100
smooth=1
Replied by Deal57 on topic Dont think my hold switch on devo 7e is working??
scooterstew wrote: hi just recently installed the latest nightly build....
any ideas???
thanks......
[Channel 3]
safetysw=HOLD1
safetyval=-100
[mixer]
src=THR
dest=ch3
curvetype=3point
points=-100,60,100
smooth=1
Time to create page: 0.055 seconds
- Dont think my hold switch on devo 7e is working??
