Picking a CC2500 module
13 Nov 2014 15:39 - 13 Nov 2014 15:39 #26389 by akcom
Picking a CC2500 module was created by akcom
Hi all, hoping for a bit of clarification here. I'd like to be able to run the FrSky protocol without a second external antenna and I've got a question. Assuming I have to use the CC2500 I'm looking at antennas. I'd like to avoid an external duck antenna if possible. I'm shooting for park range here. I've basically got three options, as far as I see it:
1. this auxillary PCB antenna
2. this chip with an integrated PCB printed antenna
3. this whip antenna stuffed in the antenna housing in the devo 7e transmitter.
I'm just wondering which one will give me the best range?
Any suggestions would be much appreciated!
Last edit: 13 Nov 2014 15:39 by akcom.
13 Nov 2014 18:53 #26393 by auceto
Replied by auceto on topic Picking a CC2500 module
Hi akcom,
I'm not an expert on this argument, so I don't know which is the best about range.
I'm going to add the CC2500 module.
I've got the aliexpress module with the external antenna and I have the same doubt of you. I don't make a hole on the case.
While I'm studing this mod I read that the antenna may be inside the tx case in orizontal position...I don't remember where was this info.
Anybody know what happen if the new antenna is in the same plastic extension of the original one? Interferences?
14 Nov 2014 17:33 - 14 Nov 2014 17:36 #26404 by magic_marty
Replied by magic_marty on topic Picking a CC2500 module
wonder if this one would work?
www.ebay.com/itm/CC2500-PA-LNA-SI4432-NR...&hash=item19d726245b
best range i have seen thus far ...could pull off the plastic antenna shielding and possible keep it inside the tx case...
How come my links not working anymore??? we can't post links anymore?
OK search Ebay for this and you will find the one it won't let me post the link to...
CC2500 PA+LNA /SI4432/NRF24L01P/A7105 wireless communication modules 2.4G 1500m
Last edit: 14 Nov 2014 17:36 by magic_marty.
14 Nov 2014 18:30 #26406 by mwm
Replied by mwm on topic Picking a CC2500 module
Are you trying to avoid the duck, or drilling a hole in your Devo? If the latter, there's a replacement for the current nub that lets you add an antenna. That should get you much better range than anything inside the 7E, especially if you used a cloverleaf instead of a duck.
If the single board module becomes a reality, I'll probably print one for my 6S.
15 Nov 2014 06:01 - 15 Nov 2014 06:03 #26414 by mikemacwillie
Replied by mikemacwillie on topic Picking a CC2500 module
For 'park range', you may want to try an internally mounted sleeve dipole. Some (but not all) of the FrSky RX antennas are sleeve dipoles. I've had good luck with these mounted internally, up near the top of the case on my Devo 10. There are a couple of places where it's mostly unobstructed by anything other than plastic in the direction that matters. The sleeve dipole antennas can be recognized by the large-ish metal cylinder right below the stripped portion of the antenna, like this one: bit.ly/1wCh9wM
This is the CC2500 module I have on both my transmitters: bit.ly/1w08Z15
Last edit: 15 Nov 2014 06:03 by mikemacwillie.
Time to create page: 0.412 seconds
