Simple way to reorder models
- MakDaddy
07 Dec 2014 13:31 #26839
by MakDaddy
Simple way to reorder models was created by MakDaddy
On my Devo 10 (4.01) I have grown in the amount of models I have. I would like to reorder them in groups to Planes, Helis, quads, etc.
Besides trying to figure out which model is in what order and renumbering the ini files, is there an easier way?
In the model screen there is:
Load
Copy to
Template
Reset.
Is there a way to add "Move"?
Maybe I am looking at this wrong. Did not see anything in the manual.
Load
Copy to
Template
Reset.
- magic_marty
07 Dec 2014 20:35 #26840
by magic_marty
Replied by magic_marty on topic Simple way to reorder models
i was thinking the exact same thing the other night when i was putting back up copies at the end of the model list and i had to copy and reset then copy again and reset ect...i thought why not have a "move to" added to this...??
maybe somebody will add it the the request and it will some day be a reality..
08 Dec 2014 03:11 #26845
Replied by mwm on topic Simple way to reorder models
Maybe somebody with the username magic_marty?
- richardclli
08 Dec 2014 05:36 #26848
by richardclli
Replied by richardclli on topic Simple way to reorder models
I have develooed a simple Java program for.this purpose.
- magic_marty
09 Dec 2014 06:27 #26864
by magic_marty
I would like if the models would show the actual names when hooked to the computer instead of model1 model2 model3 ect...
- MakDaddy
12 Dec 2014 15:16 - 12 Dec 2014 15:16 #26915
by MakDaddy
Replied by MakDaddy on topic Simple way to reorder models
I believe that Deviation was sort of based off of ER9x. It has the feature to move.
I wonder if one of these code guru's could implement this?
Last edit: 12 Dec 2014 15:16 by MakDaddy.
12 Dec 2014 19:01 #26918
Replied by hexfet on topic Simple way to reorder models
Can you share the source code?richardclli wrote: I have develooed a simple Java program for.this purpose.
12 Dec 2014 19:13 #26919
On linux I use 'grep -a name *ini'.
Looked in to this a bit. Windows XP and earlier had a straightforward way to add support for custom columns to windows explorer. In Vista and beyond it was replaced with a more complicated and less capable method. It could still be done...needs a windows codermagic_marty wrote: I would like if the models would show the actual names when hooked to the computer instead of model1 model2 model3 ect...
12 Dec 2014 19:21 #26920
Can reorder fairly quickly if you're good at sliding puzzles
Deviation supports Copy To. Click R on the File button. Move wouldn't make sense because model files are never deleted.MakDaddy wrote: I believe that Deviation was sort of based off of ER9x. It has the feature to move.
Time to create page: 0.276 seconds
- Simple way to reorder models
