Simple way to reorder models
07 Dec 2014 13:31 #26839 by MakDaddy
Simple way to reorder models was created by MakDaddy
On my Devo 10 (4.01) I have grown in the amount of models I have. I would like to reorder them in groups to Planes, Helis, quads, etc.
Besides trying to figure out which model is in what order and renumbering the ini files, is there an easier way?
In the model screen there is:
Load
Copy to
Template
Reset.
Is there a way to add "Move"?
Maybe I am looking at this wrong. Did not see anything in the manual.
07 Dec 2014 20:35 #26840 by magic_marty
Replied by magic_marty on topic Simple way to reorder models
i was thinking the exact same thing the other night when i was putting back up copies at the end of the model list and i had to copy and reset then copy again and reset ect...i thought why not have a "move to" added to this...??
maybe somebody will add it the the request and it will some day be a reality..:)
08 Dec 2014 03:11 #26845 by mwm
Replied by mwm on topic Simple way to reorder models
Maybe somebody with the username magic_marty?
08 Dec 2014 05:36 #26848 by richardclli
Replied by richardclli on topic Simple way to reorder models
I have develooed a simple Java program for.this purpose.
09 Dec 2014 06:27 #26864 by magic_marty
I would like if the models would show the actual names when hooked to the computer instead of model1 model2 model3 ect...
12 Dec 2014 15:16 - 12 Dec 2014 15:16 #26915 by MakDaddy
Replied by MakDaddy on topic Simple way to reorder models
I believe that Deviation was sort of based off of ER9x. It has the feature to move.
I wonder if one of these code guru's could implement this?
Last edit: 12 Dec 2014 15:16 by MakDaddy.
12 Dec 2014 19:01 #26918 by hexfet
Replied by hexfet on topic Simple way to reorder models
richardclli wrote: I have develooed a simple Java program for.this purpose.
Can you share the source code?
12 Dec 2014 19:13 #26919 by hexfet
magic_marty wrote: I would like if the models would show the actual names when hooked to the computer instead of model1 model2 model3 ect...
Looked in to this a bit. Windows XP and earlier had a straightforward way to add support for custom columns to windows explorer. In Vista and beyond it was replaced with a more complicated and less capable method. It could still be done...needs a windows coder :)
On linux I use 'grep -a name *ini'.
12 Dec 2014 19:21 #26920 by hexfet
MakDaddy wrote: I believe that Deviation was sort of based off of ER9x. It has the feature to move.
Deviation supports Copy To. Click R on the File button. Move wouldn't make sense because model files are never deleted.
Can reorder fairly quickly if you're good at sliding puzzles :)
Time to create page: 0.093 seconds
