Devo 12s switch assignments
14 Dec 2014 17:38 #26973 by feldmanj
Devo 12s switch assignments was created by feldmanj
Is it possible to assign the training switch to a channel? Devo 12s and Devo RX1202 Receiver .
14 Dec 2014 19:52 #26979 by mikemacwillie
Replied by mikemacwillie on topic Devo 12s switch assignments
Yep, in the advanced mixer, pick the channel you want, set mixer type to simple, the src to TRN1, type to min/max, and you're good to go.
14 Dec 2014 22:25 #26988 by feldmanj
Replied by feldmanj on topic Devo 12s switch assignments
I am not seeing the advanced mixer. I click on the plane, then into Program mix, but none of the options seem to be able to be changed. Can you provide more info?
14 Dec 2014 23:15 #26990 by feldmanj
Found it, Thanks!
Time to create page: 0.599 seconds
