Help with tx.ini
- NanoQXguy
17 Jan 2015 17:56 #27773
by NanoQXguy
Help with tx.ini was created by NanoQXguy
Hi
I am trying to check the set up of the A7105 module in my Devo 7E as I am trying to use my Devo 7E to bind to a WL Toys quad. I read the pdf for module installation and it advises to look at the modules section on the tx.ini file to enable the module.
I cannot find the "modules section". When I look at the tx.ini file on my pc it looks as if it's only showing one model in my Devo as shown below. How do I get to the modules section The previous owner of the Devo told me it has the module already installed by him.
thanks
Steve
current_model=9
language=0
music_shutdown=0
mode=2
brightness=5
contrast=5
volume=10
vibration=0
power_alarm=0
batt_alarm=4100
batt_critical=3900
batt_warning_interval=30
splash_delay=35
[calibrate1]
max=3846
min=194
zero=1859
[calibrate2]
max=3738
min=52
zero=1860
[calibrate3]
max=3710
min=88
zero=1878
[calibrate4]
max=3801
min=272
zero=1951
[touch]
xscale=197312
yscale=147271
xoffset=-404
yoffset=-20
[autodimmer]
timer=90000
dimvalue=0
[countdowntimersettings]
prealerttime=30000
prealertinterval=10000
timeupinterval=10000
[telemetry]
temp=celcius
length=meters
thanks
Steve
current_model=9
language=0
music_shutdown=0
mode=2
brightness=5
contrast=5
volume=10
vibration=0
power_alarm=0
batt_alarm=4100
batt_critical=3900
splash_delay=35
[calibrate1]
max=3846
min=194
zero=1859
[calibrate2]
max=3738
min=52
zero=1860
[calibrate3]
max=3710
min=88
zero=1878
[calibrate4]
max=3801
min=272
zero=1951
[touch]
xscale=197312
yscale=147271
xoffset=-404
yoffset=-20
[autodimmer]
timer=90000
dimvalue=0
prealerttime=30000
[telemetry]
temp=celcius
length=meters
- NanoQXguy
18 Jan 2015 10:59 - 18 Jan 2015 11:00 #27792
by NanoQXguy
Replied by NanoQXguy on topic Help with tx.ini
so I found out how to, and that I had to, add the modules into the Tx as here
www.hacksmods.com/2013/04/walkera-devo-7...x-flysky-hubsan-mod/
I have done this but still can't get the * to disappear from the protocols when going into the model on the Devo 7e
I have tried changing the last item from 13 to 14 and changing the 1 and 0 around to enable/disable the power amp.
I am now stuck. I gotta be doing this all wrong.
Can someone please help me
thanks
thanks
Last edit: 18 Jan 2015 11:00 by NanoQXguy.
- TomPeer
18 Jan 2015 12:50 #27794
by TomPeer
Replied by TomPeer on topic Help with tx.ini
did you try hardware.ini
- TomPeer
18 Jan 2015 12:59 #27795
by TomPeer
did you remove the ; in front of those lines?
- NanoQXguy
18 Jan 2015 14:49 #27807
by NanoQXguy
yep no; at all on any lines, is this what the fault is?
thanks for the help
Steve
thanks for the help
Steve
- Daryoon
18 Jan 2015 16:28 - 18 Jan 2015 16:30 #27813
by Daryoon
The HacksMods guide did have this Note about the semi colon:
Note: there are no semi colon ; preceeding the lines? The semi colon will tell the TX not to read that line, disabling the command. So make sure you remove the semicolon to “enable” the newly installed module.
Glad you got it working though.
Replied by Daryoon on topic Help with tx.ini
NanoQXguy wrote: so I found out how to, and that I had to, add the modules into the Tx as here
thanks
Last edit: 18 Jan 2015 16:30 by Daryoon.
- TomPeer
18 Jan 2015 18:09 #27820
by TomPeer
with no : at all then you should have problems. can you post your tx.ini or hardware.ini were these lines are?
- NanoQXguy
20 Jan 2015 19:24 #27894
by NanoQXguy
all fixed now guys, thanks for the help
- ursus69
20 Jan 2015 19:56 #27897
by ursus69
Replied by ursus69 on topic Help with tx.ini
Hi NanoQXguy,
Use Notepad++ (is free), and you'll see the text lines better than notepad, word or others!!
notepad-plus-plus.org/
Regards
Regards
- NanoQXguy
Time to create page: 0.105 seconds
- Help with tx.ini
