Helpppp
- saad khan
- Block137
- saad khan
- Block137
21 Jan 2015 11:21 - 21 Jan 2015 11:22 #27918
by Block137
Replied by Block137 on topic Helpppp
Swapping worked on mine.
If possible, try to test if the switch is faulty. If the switch is bad (always ON or OFF) bridge/short with a piece of wire or cutting a leg of that switch should work....
I know this is horrible idea
Last simple way is mount you 2702V backward
Hope this help
Hope this help
Last edit: 21 Jan 2015 11:22 by Block137.
- Helpppp
