Helpppp
20 Jan 2015 20:57 #27905 by saad khan
Helpppp was created by saad khan
I buy walkera receiver 2702 just now but its aile gyro reverse switch is not working. What should I do now,,,Please help me :( :(
21 Jan 2015 09:13 #27915 by Block137
Replied by Block137 on topic Helpppp
Do you mean old walkera RX2702V?
If you want to reverse AIL control, try swapping servo cable on AIL and PIT.
21 Jan 2015 11:05 #27917 by saad khan
Replied by saad khan on topic Helpppp
Yes 2702v.I swap it but still aileron gyro doesnt reverse its direction :(
21 Jan 2015 11:21 - 21 Jan 2015 11:22 #27918 by Block137
Swapping worked on mine.
If possible, try to test if the switch is faulty. If the switch is bad (always ON or OFF) bridge/short with a piece of wire or cutting a leg of that switch should work....
I know this is horrible idea :dry:
Last simple way is mount you 2702V backward
Hope this help
Last edit: 21 Jan 2015 11:22 by Block137.
22 Jan 2015 18:16 #27935 by saad khan
I checked the switch and it was working properly. so i change the reciever backwards..and it works :).. Thank you very much...
Time to create page: 0.151 seconds
