range?
14 Feb 2015 20:01 #28676 by Byington
range? was created by Byington
Does deviation increase range as well?
14 Feb 2015 22:42 #28684 by Arakon
Replied by Arakon on topic range?
No.
15 Feb 2015 11:16 #28716 by FDR
Replied by FDR on topic range?
Actually it can slightly improve the range, but only for the stock CYRF module, since it enabled the use of 150mW instead of the stock max 100mW.
It effects onty the DEVO, Walkera and DSM protocolt though...
16 Feb 2015 05:35 #28741 by mwm
Replied by mwm on topic range?
I would say that adding a CC2500, A7105 or NRF24L01 module in your Devo Tx makes an enormous improvement in the range you can get from your Devo Tx for the protocols those provide.
16 Feb 2015 11:31 #28743 by Block137
Replied by Block137 on topic range?
FDR wrote: Actually it can slightly improve the range, but only for the stock CYRF module, since it enabled the use of 150mW instead of the stock max 100mW.
Will doing so affect the life of CYRF?
16 Feb 2015 11:40 #28744 by FDR
I don't think so.
It is within the specification, not an overdrive.
IMO the output power of the CYRF is only lowered because of the type of the power amplifier used after it...
However it might have an effect on the RF output, since the PA receives a larger signal on it's input, but so far nobody has reported any issue with the 150mW setting.
16 Feb 2015 14:47 #28745 by aMax
Replied by aMax on topic range?
The CYRF itself is only up to 4dBi (2.5mW)max and the PA is designed for this
power output.
But you will achieve more range with a suitable antenna than with much output power.
Time to create page: 0.230 seconds
