range?
- Byington
- Arakon
16 Feb 2015 05:35 #28741
Replied by mwm on topic range?
I would say that adding a CC2500, A7105 or NRF24L01 module in your Devo Tx makes an enormous improvement in the range you can get from your Devo Tx for the protocols those provide.
- Block137
16 Feb 2015 11:31 #28743
by Block137
Will doing so affect the life of CYRF?
Replied by Block137 on topic range?
FDR wrote: Actually it can slightly improve the range, but only for the stock CYRF module, since it enabled the use of 150mW instead of the stock max 100mW.
It effects onty the DEVO, Walkera and DSM protocolt though...
16 Feb 2015 11:40 #28744
Replied by FDR on topic range?
I don't think so.
It is within the specification, not an overdrive.
IMO the output power of the CYRF is only lowered because of the type of the power amplifier used after it...
However it might have an effect on the RF output, since the PA receives a larger signal on it's input, but so far nobody has reported any issue with the 150mW setting.
- aMax
16 Feb 2015 14:47 #28745
by aMax
The CYRF itself is only up to 4dBi (2.5mW)max and the PA is designed for this
power output.
But you will achieve more range with a suitable antenna than with much output power.
Replied by aMax on topic range?
power output.
Time to create page: 0.186 seconds
- range?
