Downloading configs
- trhodes
21 Feb 2015 12:55 #28964
by trhodes
Downloading configs was created by trhodes
Hi All,
I upgraded my Devo 10 to deviation a month ago and absolutely love it. I wondering about the configuration files or .ini files. Are those made to be copied in the models folder and used as models or does one have to build the model in the tx from the .ini file and put in settings by hand? I can't seem to copy them. When I click on the folder or the .ini file it opens with settings in another screen.
Thanks for helping a newbie.
- mikemacwillie
21 Feb 2015 17:44 #28967
by mikemacwillie
Replied by mikemacwillie on topic Downloading configs
You can copy them into the models folder by putting your TX into USB mode. The filename needs to be Modelnn.ini, where nn is the model number you'd like to it appear as in the menu.
- trhodes
21 Feb 2015 17:58 #28968
by trhodes
Replied by trhodes on topic Downloading configs
Thanks Mike,
But how do I move or copy the file from the deviation website to my folder. Can I click and drag it?
- Cereal_Killer
21 Feb 2015 18:57 #28969
by Cereal_Killer
Replied by Cereal_Killer on topic Downloading configs
First download it. Usually you just have to click on it a few times (as you notice sometimes it just opens a new page with text, that's a web site issue cause it's in the middle of an upgrade) but if you hit back and try a few more times eventually it will give you the "save-as or open with" dialog box.
Once you download it change the name to modelnn.ini (explained above) then simply drag and drop to the model directory of your devo in USB mode. That will give you a "ok to replace" dialog, check yes / replace file and your done. Now just eject your tx from USB mode and select that model number and bind.
- trhodes
21 Feb 2015 21:53 #28979
by trhodes
Still can't get it to download. I click back and it just brings up the text. Do I need to change something in my internet settings?
- TomPeer
21 Feb 2015 21:57 #28980
by TomPeer
Replied by TomPeer on topic Downloading configs
use the right mouse button.
then "save as "
then "save as "
- trhodes
21 Feb 2015 22:28 #28982
by trhodes
Okay great, I got them to save and I saved them in the model folder on the tx. My next problem is they are not showing up in the tx when I go to load models. Any thoughts?
- Cereal_Killer
21 Feb 2015 22:42 #28983
by Cereal_Killer
What did you name them?
They must be names as "model1" "model2", not whatever you want.
- trhodes
22 Feb 2015 00:50 #28986
by trhodes
Got it!
A big thank you to everyone. I have so much to learn, but this deviation firmware is awesome.
- randal flagg
17 Sep 2015 07:57 #37818
by randal flagg
Replied by randal flagg on topic Downloading configs
can you please help I have this same problem but my right click options are
open in new tab
open in new window
copy link
select all
copy
inspect element
open in new tab
open in new window
copy link
select all
copy
inspect element
- randal flagg
18 Sep 2015 21:52 #37857
by randal flagg
firefox gave my different options on my right click solved the problem
Time to create page: 0.610 seconds
- Downloading configs
