Problem when returning to original firmware
02 Mar 2015 02:54 #29257 by ronnie918644
Problem when returning to original firmware was created by ronnie918644
I decided to return to original devo 10 firmware 0.7a/0.2. It says everything was updated successfully but now when I turn on the tx it just keeps giving me the throttle stick warning even though the throttle stick is at full down off position. Can anyone help me or is my TX toast now. I want to use the original firmware until the next version of deviation is released as I find the current intrface and having to program special for simple delta wing confuguratios complicated and a hassel as the original firmware had elevons already programmed into it. Help !!!! Thank you
02 Mar 2015 04:27 #29259 by vlad_vy
Replied by vlad_vy on topic Problem when returning to original firmware
Check 'Stick Mode' function. Probably it has 'Mode 1' by default.
02 Mar 2015 06:36 #29260 by ronnie918644
Replied by ronnie918644 on topic Problem when returning to original firmware
Thanks vlad_vy. You where correct. I just change back to mode 2 and fine !! I really appreciate your help. Have a great week !!
03 Mar 2015 20:54 #29296 by ricardo_amaral79
Replied by ricardo_amaral79 on topic Problem when returning to original firmware
I have problems to return my 7e to the original firmware. when do the process by dfuse it says concluded, but when I connect the tx appear in Chinese characters it is beeping but will not start. can someone help me?
I'm using the version I downloaded Devo7ev0.2 in the Walkera site.
thank you
Time to create page: 0.204 seconds
