What's your favorite nano size quad for Deviation?
15 Feb 2016 05:44 - 15 Feb 2016 05:45 #43138 by sauntbuckersbasket
Replied by sauntbuckersbasket on topic What's your favorite nano size quad for Deviation?
Tryptych wrote: I also have a Cheerson CX-10 but these new ones are no longer Deviation compatible
Where did you get that idea?
The later (aka green/blue) ones that use the XN297 require jumping through hoops to talk to with an NRF24L01+ type of module, but as far as I know the code to do so has been pushed.
Granted, it's a poorly performing receiver chip which means relatively short range. And the CX-10 props are rather brittle. But it should work.
Last edit: 15 Feb 2016 05:45 by sauntbuckersbasket.
16 Feb 2016 09:10 #43178 by Richard96816
Replied by Richard96816 on topic What's your favorite nano size quad for Deviation?
That's one ugly quad! :-)
I fly a lot indoors. I still prefer the Bayangtoys X9 for that. The smaller quads have a few too many problems, and not enough run time. Since I've reprogrammed some of my Eachine H8 Minis with the hackable, acro-capable firmware, that one is quickly becoming my new favorite. If you don't like any of the settings just change them.
www.rcgroups.com/forums/showthread.php?t=2512604
02 Mar 2016 18:21 #43986 by saintz
Richard96816 wrote: That's one ugly quad! :-)
This was going to be my suggestion, too. Size wise the X9 is actually bigger than the Hubsan X4, but weight wise it's a nano (a Blade Nano QX clone). Works great indoors.
25 Oct 2016 03:31 #55364 by csf2015
TomPeer wrote: Than i got unlucky too.
My v272 flies for 10 or 20 seconds and then suddenly goes quick in one direction. Absolutly unflyable.
I would not recommend this quad.
But it is good that you are happy with yours.
Me too...:(
My v272 flies for about 10 seconds and then suddenly goes quick in left direction usually...
25 Oct 2016 10:26 - 25 Oct 2016 10:29 #55369 by HappyHarry
while not as small as the cx10/11 my favourite in this size class is the jjrc h20 hex >> m.everbuying.net/product1052783.html?cur...1Sa1MGvPEaArD58P8HAQ it's a great flyer, good flight times, and a fast yaw if you have the rudder at 100% but can be easily tamed down with dual rates for less experienced fliers/small rooms, it also has a swapable lipo, plus it can fly outside in a moderate breeze 8)
Last edit: 25 Oct 2016 10:29 by HappyHarry.
Time to create page: 0.908 seconds
