Using WL-T6 adapter with other models
- jacklscott3
11 Mar 2015 01:13 #29547
by jacklscott3
Using WL-T6 adapter with other models was created by jacklscott3
Hey guys,
I've got a wl-t6 adapter (external module) that I've been using to control my v922, using the PPM Protocol. Since the 922 normally requires a nrf24l01, I'm guessing it's safe to assume the t6 adapter is using the nrf24l01 module. That being said... Is it possible to fly other models that use the same module but that are outside of the wl toys/HiSky protocol using the adapter?
A specific example would be, am i able to fly a syma x5c quad using the wl-t6 adapter?
My main concern is the fact that while using the adapter the protocol is set to ppm, so there is no way to select a different protocol.
Any ideas, or information would be very helpful!
Thank you
Jack
Thank you
Jack
11 Mar 2015 02:35 #29552
Replied by hexfet on topic Using WL-T6 adapter with other models
That adapter only supports the HiSky protocol. Not possible to fly models that use other protocols with it.
11 Mar 2015 18:52 #29571
Replied by mwm on topic Using WL-T6 adapter with other models
You might want to look into
this multiprotocol module
. It has various options to control which protocol on the module is used.
Time to create page: 0.375 seconds
- Using WL-T6 adapter with other models
