walkera devo 10, 40.1cannot bind hubsan and flysky
- vickyjim007
18 Mar 2015 10:49 #29817
by vickyjim007
walkera devo 10, 40.1cannot bind hubsan and flysky was created by vickyjim007
my control only hubsan and flysky show with (*)and can not bind i install A7105 module,i think is ini file setting problem who can help me.my setting is ; enable-a7105=A13 ;has_pa-a7105=1;
- Deal57
18 Mar 2015 11:40 #29820
by Deal57
Remove the ";" from these lines. Lines beginning with a semi-colon are comments, so remove the semi-colon. The lines should be:
enable-a7105=A13
has_pa-a7105=1
Replied by Deal57 on topic walkera devo 10, 40.1cannot bind hubsan and flysky
vickyjim007 wrote: my control only hubsan and flysky show with (*)and can not bind i install A7105 module,i think is ini file setting problem who can help me.my setting is ; enable-a7105=A13 ;has_pa-a7105=1;
enable-a7105=A13
has_pa-a7105=1
19 Mar 2015 00:13 #29858
Replied by mwm on topic walkera devo 10, 40.1cannot bind hubsan and flysky
Note that you should only uncomment the has_pa-a7015 line if you actually have a PA. Turning it off makes the Tx think it can control the power output when it can't, which will give you a setting for power that does nothing, and make you think you can do a range check when you can't.
- vickyjim007
19 Mar 2015 01:13 #29863
by vickyjim007
Replied by vickyjim007 on topic walkera devo 10, 40.1cannot bind hubsan and flysky
Time to create page: 0.293 seconds
- walkera devo 10, 40.1cannot bind hubsan and flysky
