walkera devo 10, 40.1cannot bind hubsan and flysky
18 Mar 2015 10:49 #29817 by vickyjim007
my control only hubsan and flysky show with (*)and can not bind i install A7105 module,i think is ini file setting problem who can help me.my setting is ; enable-a7105=A13 ;has_pa-a7105=1;
18 Mar 2015 11:40 #29820 by Deal57
vickyjim007 wrote: my control only hubsan and flysky show with (*)and can not bind i install A7105 module,i think is ini file setting problem who can help me.my setting is ; enable-a7105=A13 ;has_pa-a7105=1;
Remove the ";" from these lines. Lines beginning with a semi-colon are comments, so remove the semi-colon. The lines should be:
enable-a7105=A13
has_pa-a7105=1
19 Mar 2015 00:13 #29858 by mwm
Note that you should only uncomment the has_pa-a7015 line if you actually have a PA. Turning it off makes the Tx think it can control the power output when it can't, which will give you a setting for power that does nothing, and make you think you can do a range check when you can't.
19 Mar 2015 01:13 #29863 by vickyjim007
Replied by vickyjim007 on topic walkera devo 10, 40.1cannot bind hubsan and flysky
I already remove the ; but still not working ,I turn on the control show *hubsan and *flysky ,is can no bind
Time to create page: 0.689 seconds
