How does behave EXACTLY a PA ?
- NIcolas31417
28 Mar 2015 19:02 - 28 Mar 2015 19:04 #30381
by NIcolas31417
How does behave EXACTLY a PA ? was created by NIcolas31417
Hi guys,
everything is in the title:
does the selected output power affect the emmited power with a module with PA ?
if yes, does the both power add up ?
thx in advance
thx in advance
Last edit: 28 Mar 2015 19:04 by NIcolas31417.
28 Mar 2015 19:07 - 28 Mar 2015 19:07 #30383
Replied by PhracturedBlue on topic How behave EXACTLY the PA ?
The PA on the modules is always on and cannot be bypassed (generally). The PA gain is ~20dBm which is 100mW increase in power.
So if the module has a maximum output of 1mW before the PA, the output at the PA is 100mW. since most module also have very low power modes, the minimum power could be as low as 150uW, but this is still going through the PA. Not all modules support the same low power ranges.
Last edit: 28 Mar 2015 19:07 by PhracturedBlue.
- NIcolas31417
28 Mar 2015 23:29 #30389
by NIcolas31417
Replied by NIcolas31417 on topic How behave EXACTLY the PA ?
Thanks you for the reply, so it's a good thing (sometimes required) if a module has a PA.
It explain why i can fly my hex 50m away with only 150uw selected.
So i assume that all PA aren't as powerful ?
29 Mar 2015 00:11 #30390
when Deviation says 150uW, it really means 'the minimum power supported by this module' when it says 100mW it means 'the maximum power recommended for this module'. 150mW is not a recommended setting as it is very power inefficient. You get less than 12% more range for up to 2x the battery drain. the mW value is not accurate in general (though we try to get as close as we can), and it represents antenna power (not battery consumption).
All of the PA in all modules are very close in total power output. they all have a gain of ~20dBm (which is the same as input mW * 100 = output mW), and a maximum power of ~150mW. However, the CYRF6936, A7105, CC2500, and NRF24L01 all have different power output capabilities. So if you have a NRF24L01 with a PA, it probably will behave exactly like any other NRF24L01 with a PA using the same antenna.
- NIcolas31417
29 Mar 2015 08:26 #30393
by NIcolas31417
TY for having demystified this.
Time to create page: 0.158 seconds
- How does behave EXACTLY a PA ?
