NEED HELP: Syma X5C-1 Setup with Devo 7E
- 30secs
30 Mar 2015 23:18 - 30 Mar 2015 23:19 #30504
by 30secs
NEED HELP: Syma X5C-1 Setup with Devo 7E was created by 30secs
Hey all,
I've just finished installing the NRF24L01+ module. Before that i've installed the official deviation firmware, and the nightly as well. I found a couple syma x5c-1 models and added them too.
I turn on the tx now trying to bind but it doesn't. I have no idea what else i need to do.. what am i missing?!?
can someone please help me get this quad off the floor i am getting insane here...
Last edit: 30 Mar 2015 23:19 by 30secs.
30 Mar 2015 23:53 #30506
Replied by hexfet on topic NEED HELP: Syma X5C-1 Setup with Devo 7E
Have you edited the hardware.ini file to enable the nRF module?
- 30secs
31 Mar 2015 00:13 #30507
by 30secs
Replied by 30secs on topic NEED HELP: Syma X5C-1 Setup with Devo 7E
Yes i did A13 1
What am i missing?
What am i missing?
- Durete
31 Mar 2015 00:37 #30508
by Durete
Replied by Durete on topic NEED HELP: Syma X5C-1 Setup with Devo 7E
Are you sure your Quadcopter it's an X5C-1? Could be the old original version X5C?
If your Quad is the old X5C version, you need to enable the Sub-Option X5C under SymaX protocol.
- 30secs
31 Mar 2015 02:19 #30511
by 30secs
Hi durete. I am positive. What else can I check?
I've been reading your and others posts for the past two weeks and this is my first time trying this. Does it auto bind or do I need to config anything on the tx in addition to the model? How do I make sure it's using the right protocol?
Also, is there a way to check that the nrf module is working properly?
31 Mar 2015 02:59 #30512
The nightly builds that include the SymaX protocol also will show the Missing Module dialog if the nRF is enabled in hardware.ini but deviation can't read from it. You removed the semicolons on the nRF lines of that file as well as setting the values?
If the symax (or any nRF) protocol in your model has a leading asterisk it indicates a problem with the nRF module.
- 30secs
31 Mar 2015 03:02 - 31 Mar 2015 03:53 #30513
by 30secs
I formatted the drive, reflashed, and installed the nightly and used the model below. it worked!!!! woohooooo
only thing is when i raise the throttle the quad immidiately banks hard to the right. i tried it with the JJRC H8C quad with same result. Any idea what's causing this? I've calibrated the tx 5 times. Maybe i'm not calibrating it right or does it need a config change?
Last edit: 31 Mar 2015 03:53 by 30secs.
- 30secs
31 Mar 2015 14:51 #30549
by 30secs
Also, yesterday I sorta got it to balance but this morning when I turned it on same issue... What's wrong?
31 Mar 2015 15:56 #30553
Can you keep it level with stick inputs? Does the quad have an auto-level calibration procedure?
- Tryptych
31 Mar 2015 16:23 #30556
by Tryptych
I don't see your model.ini posted here, attach it if you're still having problems.
Replied by Tryptych on topic NEED HELP: Syma X5C-1 Setup with Devo 7E
30secs wrote: and used the model below.
- 30secs
31 Mar 2015 16:28 #30557
by 30secs
Yes if I bank hard the other way it stayed stable but as soon as I let go it banks hard. I've also tried trimming which didn't work. The syma x5c1 and jjrc h8c both have standardizing gyros, and both ate having the same issue (as well as the syma x11), which made me realize it's not a model setting but a tx issue.
- aMax
31 Mar 2015 17:20 #30559
by aMax
Replied by aMax on topic NEED HELP: Syma X5C-1 Setup with Devo 7E
Sticks calibrated after Deviation install?
- 30secs
31 Mar 2015 17:23 #30560
by 30secs
Yes. About 10 times. Is there a wash to calibrate it? It seems every time I try to calibrate it gets out of whack in a different way
- 30secs
02 Apr 2015 14:39 #30693
by 30secs
Does anyone have an idea? It keeps banking or studying regardless of how many calibrations. Sometimes it even changes when the quad lands.
Could it be an nrf wiring problem? What else could it be?
02 Apr 2015 17:34 #30700
How does it fly with the stock tx?
Does the aileron channel look correct in the channel monitor? Zero when the sticks are centered and symmetric travel?
- 30secs
02 Apr 2015 19:51 - 02 Apr 2015 20:14 #30707
by 30secs
Hi hexfet, the stock tx with my quads fly fine. It's when i try to use the Devo it banks hard or does other non-stable alighnment. It does it with all the quads (syma s5c, jjrc h8c, syma x11).
checked channel monitor, after calibration --
aileron neutral: -23
left: 35
right: 59
Sometimes i get 60 even, then after a few minutes it changes.
Also, when i push right, the numbers flicker sometimes, they don't stay fixed.
Could it be a soldering issue? Which connection controls aileron on the PCB/nrf module?
left: 35
right: 59
Last edit: 02 Apr 2015 20:14 by 30secs.
02 Apr 2015 22:47 #30716
That behavior seems like a hardware issue. Maybe with the roll potentiometer or its connections. Does the stick input screen show the same behavior?
The interface to the nRF module is digital - all the channel data goes over the same connection. It's very unlikely a problem there would only affect roll.
- 30secs
05 Apr 2015 21:09 #30811
by 30secs
hey hexfet. i replaced the knob part that cause the issue and it's working well now. Thanks!
Time to create page: 1.304 seconds
- NEED HELP: Syma X5C-1 Setup with Devo 7E
