Switch assignment on Devo 10
05 May 2015 14:07 #32105 by Skysurfer
Switch assignment on Devo 10 was created by Skysurfer
Need to assign the f mode switch so I can toggle the flight mode in my CC3D setup. How to assign a f mode switch in the Devo 10
05 May 2015 14:33 - 05 May 2015 14:40 #32109 by Cereal_Killer
Replied by Cereal_Killer on topic Switch assignment on Devo 10
Post your current model file and I'll do it for you. Pretty much it's about as simple as it gets tho- just create a new channel (channel 5) and set it's source to FMODE then mix in MFODE1 and FMODE2. The actual mode switching is done on the FC end, the Tx simply sends a value, low, mid or high.
[channel5]
scalar=100
template=expo_dr
[mixer]
src=FMODE0
dest=Ch5
[mixer]
src=FMODE0
dest=Ch5
switch=FMODE1
scalar=0
[mixer]
src=FMODE0
dest=Ch5
switch=FMODE2
Note this method only works on the newest FW's / nightlies where each switch position is technically a different switch, if you're using an older version of the FW it'll be a bit different because back then each switch position was a different value for the same switch, I dont remember exactly how but it would look something like FMODE = -100, 0 or 100.
Last edit: 05 May 2015 14:40 by Cereal_Killer.
05 May 2015 14:55 - 05 May 2015 14:56 #32113 by Skysurfer
Replied by Skysurfer on topic Switch assignment on Devo 10
Current model file is just a generic model5.ini file that is present when choosing a new model No alterations have been done to the model5 file.
I can't upload right now as I am charging my tx batteries.
I am running deviation 4.0.1 should I upload the latest nightly build for this ?
Last edit: 05 May 2015 14:56 by Skysurfer.
05 May 2015 16:21 #32120 by Skysurfer
Here is my model5.ini file pretty generic.
05 May 2015 16:24 #32121 by Skysurfer
Whoops named it wrong , converting to txt file for attachment purposes.:
Here is model5.txt
05 May 2015 16:26 #32122 by Cereal_Killer
Go ahead and apply the code snipit I posted to your file and give it a shot.
Note I have no idea anything about CC3D or how to set it up on that end. That'll be on you. I imagine there's some sort of RC data display in the GUI you can watch to see if the switch is changing stuff.
05 May 2015 16:33 #32123 by Skysurfer
Thanks cereal, I just append the snippet to the end of the code?
Where Do I insert the code/position it.
05 May 2015 16:42 #32126 by Cereal_Killer
Always keep your channels in numeric order.
Note you may or may not need to reverse the channel, if so you'll need to reverse each of the SRC's, not only one (also you'll need to change the scale to -100)
05 May 2015 17:57 #32128 by Skysurfer
Cereal you are the man! Works great thank you!
Time to create page: 0.085 seconds
