Newbie battery question for Devo F12E
05 May 2015 21:59 #32134 by cirymarr
Newbie battery question for Devo F12E was created by cirymarr
Hi
I received my new Tali H500 with Devo F12e today - the F12e didn't have a battery pack included.
As I am a complete newbie, I have been scouring the website where I purchased the H500. Is this battery ok to use with the F12e: www.banggood.com/Wholesale-Lion-Power-11...y-BT693-p-65964.html
I want to ensure the specs are correct and that I don't need to worry about changing connectors etc.
Many thanks
06 May 2015 02:27 #32140 by PhracturedBlue
Replied by PhracturedBlue on topic Newbie battery question for Devo F12E
I just bought this, and it seems to work fine in my F12E:
www.hobbyking.com/hobbyking/store/__3131...ransmitter_Pack.html
I'm sure any equivalent battery will work. note that the F12E doesn't include a lipo battery charge cicuit, so you need to remove the battery to charge it. youcould probably find nimh packs that you could charge with a 12V wall-wart
06 May 2015 03:59 #32154 by Block137
Replied by Block137 on topic Newbie battery question for Devo F12E
Any 2S-3S Li-Po should work (& 8S NiXX <<< Dont do this! That thing weights a ton already)
Mine is sharing battery with 450 heli no problem (11.1V 2200mAh)
And you can charge it with H500 charger
Time to create page: 0.056 seconds
