Please help Devo 12s fonts is out of wack
- mrbeefy
06 May 2015 01:22 #32135
by mrbeefy
Please help Devo 12s fonts is out of wack was created by mrbeefy
i tried everything from nightly to the latest to even the oldest firmware but after updating the firmware and the library the fonts is just messed up , can any here help me and point me in the right direction.I was able to install the deviation on my older 12s which i sold now i just bought another one but this time its a nightmare to update the firmware . Please help.
06 May 2015 01:47 #32136
Replied by PhracturedBlue on topic Please help Devo 12s fonts is out of wack
That is really weird. The white boxes around everything indicate that transparency isn't working and that white is being printed wherever transparency should be, but that makes no sense. have you put the Walkera firmware back on and made sure it works properly?
I guess it is possible they used a different version of the LCD driver, but it seems unlikely. taking a piicture of the LCD chip inside might help.
You could also try using 'verify' to check the devo12-lib.dfu was uploaded properly (make sure to use a freshly unzippped copy to verify (note, you can't verify the firmware, only the library)
- mrbeefy
06 May 2015 01:57 #32137
by mrbeefy
Replied by mrbeefy on topic Please help Devo 12s fonts is out of wack
yes sir originally it was 1.6 but i can only restore it using the 1.5 and it works with the factory firmware but every time i install any build i tried them all it just shows a garbage text I just got this TX today and im worried that walkera made some changes internally on this TX. Please help
- mrbeefy
06 May 2015 02:17 - 06 May 2015 02:19 #32139
by mrbeefy
i tried installing from scratch and verified the lib file and all is good but still doing the same thing , everything works fine i just cant see the text. Here's more pics.
Last edit: 06 May 2015 02:19 by mrbeefy.
06 May 2015 02:50 #32142
it definitely is the transparency that isn't working. It has nothing to do with the filesystem I think. The question is why it doesn't work.
I checked the manual for the S1D13517, and the 1.5 manual says:This is a change from the 1.2 spec which didn't include that last bit.
We normally set '52h=0x0b' and it has always worked in the past. So it looks like Epson may have made a minor revision and something that used to work no longer does.
The good news is that I am sure this can be worked around. The bad news is that I have no idea how yet. The reason we use flipped images is because the bmp format is drawn from the bottom to top. I will need to do some experimentation to figure out a reasonable solution.
A transparency function is available for image data writes. When enabled, input image data matching a specified
key color is not written to the memory. This function can be used to overwrite text and icons in display data. This
function can not be used with rotation and mirror function, the REG[52h] bits 3-0 never be set to the value 9h,
Ah and Bh.We normally set '52h=0x0b' and it has always worked in the past. So it looks like Epson may have made a minor revision and something that used to work no longer does.
- mrbeefy
06 May 2015 02:58 - 06 May 2015 03:01 #32143
by mrbeefy
thank you for your quick reply but i guess the best way is to just return this from where i bought it, i love this tx and planning to install some modules to work with my micro quads . Im still hoping for a solution as i really dont want to return this.
Really looking forward for your solution,
Last edit: 06 May 2015 03:01 by mrbeefy.
06 May 2015 03:09 - 06 May 2015 03:11 #32144
Try this:
www.deviationtx.com/downloads-new/catego...e-devo12-lcd1-5-test
It will have all the images flipped upside down, but if the white boxes are gone and the fonts are readable, it at least will prove that my analysis is correct.
Edit: FYI, if that does work, we can easily build you a custom filesystem with flipped BMP files so you can use Deviation while I work on a proper fix.
Last edit: 06 May 2015 03:11 by PhracturedBlue.
- mrbeefy
06 May 2015 03:15 #32145
by mrbeefy
ill test it right now
- mrbeefy
06 May 2015 03:25 - 06 May 2015 03:25 #32146
by mrbeefy
pictures are all upside down.
im not losing hope.
Last edit: 06 May 2015 03:25 by mrbeefy.
06 May 2015 03:49 #32148
darn. That is not what I wanted it to look like. Upside-down is expected. the white boxes and lack of text is not
Try this:
www.deviationtx.com/downloads-new/catego...-devo12-lcd1-5-test2
If you still don't see the fonts, I will need to do some investigation to figure out what is wrong which might take some time.
Try this:
- mrbeefy
06 May 2015 03:54 #32150
by mrbeefy
doing it now
- mrbeefy
06 May 2015 03:58 #32152
by mrbeefy
holy macaroni it worked!!!! i can see the text now although the text is still upside down but the white part is gone!!! Your awesome sir!
- mrbeefy
06 May 2015 03:59 #32153
by mrbeefy
can you correct the text please
06 May 2015 04:01 #32155
can you post a screen-shot?
I want to make sure it looks as I expect.
I will then give you 2 other builds to see if they change anything. I need to know which changes I made are making it work.
- mrbeefy
06 May 2015 04:01 #32156
by mrbeefy
heres the picture
- mrbeefy
06 May 2015 04:09 #32157
by mrbeefy
fonts are all in correct orientation just the graphics.
06 May 2015 04:10 #32158
good. that is exactly what I wanted it to look like.
The these:
www.deviationtx.com/downloads-new/catego...-devo12-lcd1-5-test3
please try both the _2 and the _3 and post screenshots of both of them they may either or both be worse than what you have now. I just need to know which change I made has an effect
The these:
- mrbeefy
06 May 2015 04:13 #32159
by mrbeefy
doing it now
- mrbeefy
06 May 2015 04:25 #32160
by mrbeefy
heres the 2nd firmware
- mrbeefy
06 May 2015 04:29 #32161
by mrbeefy
3rd firmware , back to the same problem so firmware 2 fixes everything
Time to create page: 0.223 seconds
- Please help Devo 12s fonts is out of wack
