Base config for Cleanflight?
- ozziegt
08 May 2015 02:25 #32235
by ozziegt
Base config for Cleanflight? was created by ozziegt
I am setting up my first custom quad with Cleanflight. I have a Devo 8S transmitter and a OrangeRx 615x. Is there a base config I can use which at least has the 4 primary channels set up so I can try to fly the copter?
- Cereal_Killer
08 May 2015 17:43 - 08 May 2015 17:45 #32258
by Cereal_Killer
Replied by Cereal_Killer on topic Base config for Cleanflight?
DSMX / DSM2 literally could not be more simple to setup. I'll post mine to get you going but you may as well just configure one from scratch so it's setup EXACTLY how you want. It'll be good for you in the long run so I suggest using mine as a guide and starting a new one on your own, again it's so easy to setup DSMx that it's a good way to learn and will help you when you need to eventually setup one more advanced.
Note it's doubtful my sub-trims and endpoints will be the same as yours, you'll have to adjust to your specific build as needed.
Last edit: 08 May 2015 17:45 by Cereal_Killer.
- ozziegt
10 May 2015 23:47 #32369
by ozziegt
Replied by ozziegt on topic Base config for Cleanflight?
Thanks Cereal Killer! Or should I call you count chocula? lol
Time to create page: 0.124 seconds
- Base config for Cleanflight?
