Bad missing protocols modules Devo 7e
10 May 2015 14:29 #32348 by norris
Still can't get this pile of crap to work HELP NEEDED PLEASE!!!!!!!
10 May 2015 16:41 #32353 by Cereal_Killer
Replied by Cereal_Killer on topic Bad missing protocols modules Devo 7e
Some info would really help.
Feel free to send it to me if you give up!
10 May 2015 21:59 #32367 by norris
Replied by norris on topic Bad missing protocols modules Devo 7e
It seemsto be loaded with information namely deviation but when I look for models and change the protocol I just get - Bad/missing protocols.
I can't even return it back to devention as Walkera have pulled the plug on it.
All I want to do is fly my V120DO2S.
11 May 2015 00:21 - 11 May 2015 00:23 #32370 by Cereal_Killer
Again we need more info, what version of deviation? What directions did you follow to flash it? You did format and then copy over all the files including the protocol directory right (protocol is ONLY NEEDED ON YHE 7E, if you foowed other directions you may have missed it).
In order to get the answer you need you must provide us with as much info as possible. You'd get more replies if you give more info.
What you're trying to do (fly a Devo model) is the easiest thing to do with our tx's, I'm sure you can get it going but as it stands it seems like you're unwilling to help yourself. Just sayin...
Edit: there's no reason to but you can always return to stock, I've seen the link posted for stock 7E FW just within the last few weeks. Again I'm sure you can get deviation working but at the very least it's not bricked.
Last edit: 11 May 2015 00:23 by Cereal_Killer.
11 May 2015 09:48 #32385 by aMax
Replied by aMax on topic Bad missing protocols modules Devo 7e
Original firmware for Walkera TX ( german = "Sender") is to be found here ......
walkera-fans.de/downloads/
11 May 2015 21:25 #32409 by yogi b
Replied by yogi b on topic Bad missing protocols modules Devo 7e
I just got this message
and corrected it by installing the protocol folder
deviation-devo7e-cmpang_2013-02-12-3.zip - ZIP archive, unpacked size 356,402 bytes
just about to try to fly my nano
11 May 2015 23:05 #32410 by norris
Do you have a link please?
11 May 2015 23:08 #32411 by PhracturedBlue
Replied by PhracturedBlue on topic Bad missing protocols modules Devo 7e
You need to use the modules that come with the dfu file you installed. so if you are using the official 4.0.1, then use the 'protocol' folder that comes with it.
If you are using a test-build (Downloads->Test Builds) then again use the protocol folder that comes inside the zip. the key here is to 1st install the dfu, then immediately afterwards install the .mod files
11 May 2015 23:13 #32413 by norris
There's not really any more information that I can give.I've read the manual,watched the video's but haven't actually found something to make it work yet.
When you turn it on Deviation 4 comes up on the screen all the require files are there yet going through the menu no models actually show up apart from the one I did manually.
It seems the lights are on but there's no one at home!
11 May 2015 23:47 - 11 May 2015 23:49 #32415 by yogi b
let me start from the begining
i down loaded the 4.01 ver for the 7e here
www.deviationtx.com/downloads-new/category/12-deviation-4-0-1#
downloaded to my desk top
and extracted to a new desktop file folder
it contained the dfu file
which was upgraded to the transmitter
using the walkera upgrade tool
every thing went fine for me
the zip file and the .dfu file were deleted from the desk top folder
and this folder was transferred to the transmitter
via usb connection, after the transmitter drive was formatted
turn off, transmitter
turn on
SHEER PANIC
same message you got
searching thru my deviation folder
i found this
now i can't find where i got it
it had just a protocol folder
and 2 zip files
i used this protocol file to overwrite the original one
i noticed, it not only replaced some files but added some as well
and bing, bang, boom, everthing worked
btw
i did forget to turn up the range
but set it at 150mw instead of 10mw
the blade nano flew fine
Last edit: 11 May 2015 23:49 by yogi b.
11 May 2015 23:56 #32416 by yogi b
mine just goes to the model set
no deviation intro
maybe i don't have it right yet
but you can imagine how happy i am
i flew somthing with it
lol
anybody know where i could have gotten that protocol set from?
and what did i do wrong initially?
that the original message came up?
thanks everybody
and norris
hang in there
we will get it
12 May 2015 00:01 #32417 by yogi b
"use the 'protocol' folder that comes with it."
i did
got the same message
solved it as above
yes, i'm scratching my head too
can't figure out what i did wrong
does the protocol folder have to go anywhere else?
12 May 2015 02:05 #32419 by Cereal_Killer
yogi b wrote: let me start from the begining
POWER OFF
power back on (in regular USB mode, NOT dfu mode)
FORMAT DRIVE
Copy all files / directories over
power off
turn on
SHEER PANIC
i found this
and 2 zip files
btw
I added several steps in to your order, make sure you dont skip any of them
12 May 2015 12:15 #32440 by yogi b
Thanks for making that clear
i did follow those steps
but did not write them in
i think we have it now
norris try the procedure Cereal_Killer laid out
yes start from the beginning
let us know
12 May 2015 21:21 #32470 by norris
I've reloaded Deviation as it wouldn't load Devention from the German site so I can't return it back to original form.
It has model 1 and model 3 assigned as model but nothing else.
Just need a file for a V120DO2 to download onto it.
Thanks.
Time to create page: 0.785 seconds
