Devo 8s and rx601, Help with aux channel
- ronzer
17 May 2015 02:02 #32678
by ronzer
Devo 8s and rx601, Help with aux channel was created by ronzer
I have a Devo 8s with Deviation 4.1 and using a rx601 and I cant get the 6 channel witch is aux channel to work. I want to assign a switch to the 6 channel.Can it be done?
Thanks for any Help.
17 May 2015 12:24 #32686
Replied by mwm on topic Devo 8s and rx601, Help with aux channel
Yes. Well, in the Advanced GUI, anyway. Just go to the channel six mixer, set a simple mix, and set the SRC to the switch you want to use.
If you need to do setup in the Standard GUI, you can switch to it and not lose your setup, and then turn the switch on. However, you can't switch back, so you might want to wait and see if someone who uses the Standard GUI has an answer for you.
- ronzer
17 May 2015 15:13 #32690
by ronzer
Replied by ronzer on topic Devo 8s and rx601, Help with aux channel
Thanks that helps I got it .
Time to create page: 0.222 seconds
- Devo 8s and rx601, Help with aux channel
