Devo 10 (v4.0.1) lag on Blade 200 SRX controls
27 May 2015 13:28 - 10 Jun 2015 06:25 #33049 by goose969
Hi Forum,
1st of all: SORRY for my bad english! I am from germany and it is quite a while from my schooldays until today...
This is my problem I would like to discuss on this forum:
I am having a problem with my Blade 200SRX; all controls show a lag of about 2-3 tenth of a second, which leaves my Heli quite unflyable.
The same TX works perfectly fine with my Blade Nano QX and Blade MSR.
The Blade 200 SRX works perfectly with my Dx6i (no lag).
I tried rebinding the 200SRX and using another ini-file but the lag remains uneffected.
So I kindly ask for a hint leting me find the solution for this lag, since I have not got any idea about the origin of this uncommen problem (uncommon because I could not find any similar problem on the internet)
Thank you for reading so far
Regards
Last edit: 10 Jun 2015 06:25 by goose969.
27 May 2015 15:35 #33057 by Stavross118
Replied by Stavross118 on topic Devo 10 (v4.0.1) lag on Blade 200 SRX controls
I to also found there was a lag........so went across to the nightly builds as I could not get switching to work I have included a model ini for this in the model section ....
You never know try it and see??
Hope this helped
28 May 2015 03:03 #33092 by mwm
If you're using DSMX, try DSM2, and vice versa. Also, make sure you've only got six channels configured on the Tx. I've never had a problem with mine, whether running 4.0.1 or the nightly builds.
29 May 2015 22:23 - 29 May 2015 22:24 #33224 by Thomas.Heiss
Replied by Thomas.Heiss on topic Devo 10 (v4.0.1) lag on Blade 200 SRX controls
Not sure about the 200SRX lag but since only the nightly-build versions will let you:
- display 9999 numbers (>255) in telemetry flightlog display
- higher framelosses and hold numbers to tweak the 200SRX setup gain numbers
I would suggest you give it a try.
We especially extended the telemetry just for 180CFX and 200SRX.
You might also want to give one of the Indigo/Vlad DSMx protocol + telemetry re-engineering test-builds for the 200SRX a try and see if it improves on your side for DSMx.
Sorry, but I do not own a 200SRX. 200QX was fine.
Have you already put up throttle >100% (yes of course this has nothing to do with a protocol / steering lag).
Greetings
Thomas
Last edit: 29 May 2015 22:24 by Thomas.Heiss.
01 Jun 2015 08:20 #33312 by goose969
Replied by goose969 on topic Devo 10 (v4.0.1) lag on Blade 200 SRX controls
Thx for the tips so far - So the new roadmap is:
- try another ini-file
- change the protocol (dsm 2/x)
- check the number of channels defined (think it is 4 for steering plus 1 for panic + 1 for flightmode which would be exactly 6)
- flash a nightly-devo-fw
I think(!) I already made a protocol-change (dsm 2/x) but I am not sure wether I did a rebinding, so I will check that (again)
@thomas.heiss: Yes, I put up throttle to 200% (Gain 4 as far as I remebember), but I still think about another motor-pinion (12 teeth)
05 Jun 2015 16:55 #33478 by goose969
Hi there, the lagg-man again ;)
1st of all: It works!!!!!
I tried another ini (model4-slot - the lagging showed at model3-slot), did the binding and "VOILA" no laggs anymore.
But the weird thing is now to come: Also the model-3-slot-ini works now WITHOUT laggs.
So it could have been just a binding issue (kind of "human error" you know ...)
Anyway: THX to all that tried to help me !
GONE FLYING ...
07 Jun 2015 21:43 #33594 by Thomas.Heiss
no, don't fly with DSM2 which may use two channels which are near to each other (in the worst case): www.rcmodelreviews.com/dsm2flaw.shtml
You better use DSMx as true FHSS hopping system.
According to ETSI V1.8.1 it is prohibited to use 2-3 channel DSSS protocols in DE (complete EU?) starting 01/01/2015 any way.
09 Jun 2015 07:08 #33690 by goose969
I am using the proper DSMX-Protocol, since everything is working fine now (s.a.)
Time to create page: 0.776 seconds
