Master CP gyro (6 axis)
- aperseghin
29 May 2015 18:24 #33197
by aperseghin
Master CP gyro (6 axis) was created by aperseghin
Does the gyro work with Deviation properly?
Where are gyro gains set in Deviation?
29 May 2015 20:04 #33207
Replied by mwm on topic Master CP gyro (6 axis)
Yes, as the Gyro is part of the model, not the transmitter.
In the Standard GUI, just find the Gyro icon, and set them there. I don't use it, so I can't provide details. Those can be found in the manual that you can download via the "User Manual" links to the left.
In the Advanced GUI, you need to set up the channel connected to your Gyro using Fixed curves with the appropriate output enabled by whatever switch you desire.
- Thomas.Heiss
07 Jun 2015 22:17 #33601
by Thomas.Heiss
Replied by Thomas.Heiss on topic Master CP gyro (6 axis)
MasterCP has FBL (including gyro) + receiver all-in-one in one module - just like Spektrum AR7200BX does it for example.
It uses the Walkera DEVO protocol.
So yes, it will work with DeviationTX.
Time to create page: 0.691 seconds
- Master CP gyro (6 axis)
