Devo 10
- SilbernerSurfer
02 Jun 2015 14:10 #33364
Replied by mwm on topic Devo 10
What voltage level are you asking about? Power or charge?
For power, I use LSD NiMH's in mine, which typically show 8.5 to 9 volts. Haven't gotten a warning in a while, but you do get a warning about no longer being able to save model data to flash once the power gets to low.
If you're asking about charge levels, that should be on the side of the Tx, next to the charge port.
- SilbernerSurfer
- SilbernerSurfer
05 Jun 2015 15:56 #33477
by SilbernerSurfer
Replied by SilbernerSurfer on topic Devo 10
After using the Devo 10 with a sim for abot 90 min or settings the batterys are dropping voltage. The volts are jumping from 8.3 to 8.6. I get the massage "Battery too low, no saving data". When i power the Devo off i cant power it on again. i have to wait a minute and after this the Devo powers on and shows about 9.5 volts. Brandnew batteries, only one charging cycle.
Are the batteries faulty?
- SilbernerSurfer
- aMax
06 Jun 2015 14:40 - 06 Jun 2015 14:44 #33551
by aMax
Replied by aMax on topic Devo 10
This can't be answered as long you do not tell us what kind of batteries you are using.
If NiMh, the lowest voltage per cell is 1V before breaking completely down. So a warning at 1.1V per cell is advised.
The Devo10 consumes ca 200-220mAh ....if at 150 mW it might be little more,.......do the math.
Edit: The system itself is a 3.3V system, so you have to monitor your cells!
Last edit: 06 Jun 2015 14:44 by aMax.
Time to create page: 0.703 seconds
- Devo 10
