Flying Delta Wings Planes
- chat2000
07 Jun 2015 20:04 #33591
by chat2000
Flying Delta Wings Planes was created by chat2000
i have a devo 10 and wanted to fly a delta wing airplane. I could make right and left turn work perfectly but my problem is going up and down. They are reverseg e.g. when i press the right stick up the plane goes up but it should go down.
I tried reversing the channles but the problem is that i could not found the channel for up and down in delta wing mode.
Do you have any suggestions what i could try?
With best regards
With best regards
- Cereal_Killer
08 Jun 2015 02:42 #33613
by Cereal_Killer
Replied by Cereal_Killer on topic Flying Delta Wings Planes
You'll need to setup an elevon mix. What rx? If speltrum based I can post my .ini for a dsm2 wing I have, if not you can search for how to setup an elevin mix, there's a great tutorial which is how I learned to set mine up.
Do you have a rudder or a true wing?
- blackmoon
08 Jun 2015 16:07 #33634
by blackmoon
Replied by blackmoon on topic Flying Delta Wings Planes
Could you please post your model file, thx.
- Cereal_Killer
08 Jun 2015 17:24 - 08 Jun 2015 17:31 #33639
by Cereal_Killer
This is for my versa-wing running a DSM2 LemonRx. Note channel 3 is bad on my Rx so I'm using 1 2 and 4, either wire your receiver the same or change ALL the Ch4 names back to 3 (you cant just change the label, you MUST change all the destinations of the mux too!!). Also note, this is setup for 3 dual rates, low/mid/full on the right add-on 3-was switch (SW B ) and a throttle safety / cut on the left 2-way.
My plane flies but you may need to do some channel reversing and such. Sorry, I dont remember which elevon is which channel, I believe left wing is CH2 and right wing is CH4.
Edit: The first file I posted was titled correct but was the wrong file, THIS is the correct one!
sorry
sorry
Last edit: 08 Jun 2015 17:31 by Cereal_Killer.
- blackmoon
10 Jun 2015 06:49 #33760
by blackmoon
Thank you, I'll look into it. I'll have to convert it to the Flysky channel order but it's easy enough, I needed to see how you did the mixing that's the tricky part.
10 Jun 2015 17:02 #33779
Replied by mwm on topic Flying Delta Wings Planes
Just a warning: we see a lot of issues regarding either Channel 1 & 3 being "swapped", or the Tx being in the wrong mode (1 instead of 3 or vice versa). I'm starting to suspect that these are related to converting to/from DSM channel order (everybody else seems to do it the same way).
While it ought to be easy, either it confuses people more than I think it should, or the firmware is screwing things up. Or maybe my suspicion is wrong. So be careful. Maybe convert a copy, and then compare them afterwards? And if you catch it screwing things up, open an issue and attach both the original and the just-after-conversion model files.
- blackmoon
11 Jun 2015 20:44 #33873
by blackmoon
I guess this just happens when you use the transmitter to make the conversion, I always edit my model files on my computer then test them without props on, a quad going full throttle with props on it is enough one time in my entire life. Now each model has his motor disconnected or props removed before testing.
Never done a conversion from/to DSM, I'll double check tough.
Thank you.
Thank you.
Time to create page: 0.406 seconds
- Flying Delta Wings Planes
