DSM2 does not support auto-binding.
- liliass
03 Jul 2015 06:55 - 03 Jul 2015 07:02 #35032
by liliass
DSM2 does not support auto-binding. was created by liliass
I just ordered OrangeRX R615X and it is on the way. However when I went through the documents and i found this
What does it mean ?
How do I bind with my Devo 10 flashed with v4.0.1?
can someone provide me a video or procedure how to bind it ?
If Fixed ID is set to None, a transmitter-specific ID is used instead. It is necessary to manually bind each model before the first use.
What does it mean ?
Last edit: 03 Jul 2015 07:02 by liliass.
03 Jul 2015 07:08 - 03 Jul 2015 07:12 #35033
Replied by vlad_vy on topic DSM2 does not support auto-binding.
As any other DSM2 transmitter. Insert bind plug to Rx, power on Rx. At Tx side, open Model Menu, Model Setup, scroll down to Bind button and press ENT. After complete binding, power off Rx and pull out bind plug.
Last edit: 03 Jul 2015 07:12 by vlad_vy.
- aMax
03 Jul 2015 07:52 #35036
by aMax
Replied by aMax on topic DSM2 does not support auto-binding.
.... why not use DSMX with that rx? Then it works like a charm.
- liliass
03 Jul 2015 08:39 #35042
by liliass
Replied by liliass on topic DSM2 does not support auto-binding.
So DSMX OrangeRX R615X work out of box with Walkera Devo 10 ?
My setup :
FC: Naze32 Cleanflight 1.9
My setup :
- Thomas.Heiss
03 Jul 2015 10:06 #35047
by Thomas.Heiss
Replied by Thomas.Heiss on topic DSM2 does not support auto-binding.
Spektrum receivers have no AUTO-binding like Walkera DEVO receivers.
There is no difference if DSM2 or DSMx.
Spektrum transmitter manuals (e.g DX6, DX8) describe the bind process with the bind plug.
Only the DSM2 quick connect / brown-out feature (orange blinking led) works different than for DSMx receivers.
Existing "auto-bind" thread and two linked Mantis bug tracker links (the 2nd described the DSM2 quick connect / brown-out detect):
www.deviationtx.com/forum/7-development/...2801-dsm2-dsmx#34296
03 Jul 2015 20:57 - 04 Jul 2015 04:15 #35059
"Auto-bind" in protocols that support it is a feature where you can set the Fixed ID to None, and the Tx will come up and bind with any available receiver. This is convenient if you want to fly lots of aircraft with one model on your transmitter, or if you are using a transmitter without multiple model support. It's also dangerous, as you can wind up flying an aircraft with the wrong - and completely inappropriate - model file. For instance, any simple four-channel aircraft using a helicopter model that does swash mixing.
As noted, neither DSM protocol supports autobinding. Deviation treats the fixed id of None as just another possible value for the ID.
Replied by mwm on topic DSM2 does not support auto-binding.
liliass wrote: I just ordered OrangeRX R615X and it is on the way. However when I went through the documents and i found this
What does it mean ?
Last edit: 04 Jul 2015 04:15 by mwm.
- RoGuE_StreaK
04 Jul 2015 01:02 #35070
by RoGuE_StreaK
Replied by RoGuE_StreaK on topic DSM2 does not support auto-binding.
Yes. DSM2 and DSMX will work with a non-modified "deviated" Devo 10. I think the auto-bind thing is just confusing the issue; it just means that to bind the first time you need to plug in the bind plug, after that it'll bind whenever you turn it on. The stock Walkera protocol allows you to bind the first time WITHOUT a plug by using "auto-bind".liliass wrote: So DSMX OrangeRX R615X work out of box with Walkera Devo 10 ?
Time to create page: 0.215 seconds
- DSM2 does not support auto-binding.
