Devo F12E as a one for all solution.
04 Jul 2015 02:41 #35072 by Daos
Hi there guys!
I have just ordered a Devo F12E transmitter, because I have an Scout x4
But I love more my personal projects than my scout, so I definately need to use the same F12e receiver on my other quads, currently I have a 450 with an APM 2.5 board and a 250 with a naze32 board.
I have been reading a lot today about the mods and PPM PWM and other stuff I did not know anything about hahaha but I have come across to something that to me feels more practical, the A7105 module.
I just want to ask, if I add and solder this module to my Devo F12e TX, I understand it will be compatible with Turnigy, Flysky and FrSky protocols (If I'm wrong please let me know) and with any of this receivers I will be able to use my Naze32 or APM, what concerns me is if it will still be compatible with regular DEVO Rxxxx series receivers.
Any help would be appreciated, even if you have a personal opinion or another solution to my needs it's all welcome.
I just want to use this great TX on all my quads.
04 Jul 2015 03:08 #35073 by Daos
Replied by Daos on topic Devo F12E as a one for all solution.
Hahahha all this reading and I didn't realize that there is no firmware atm from Deviation for the F12e
Do you guys think that the RX703A wich has PPM will be enough for the APM 2.5 with gps and telemetry? Because it seems that's going to be my only solution atm
04 Jul 2015 03:48 #35075 by Daos
Upon further investigation I found out that the rx601 and rx701 can work with my 250 quad and the rx1002 can work with my 450 quad with APM 2.5 as long as I use them both with PWM connections.
Is this right? I don't want to screw it up ordering receivers that I won't need...
04 Jul 2015 04:14 #35076 by mwm
Replied by mwm on topic Devo F12E as a one for all solution.
Let's see:
The F12E support is in the latest nightly builds. Go to Downloads, nightly builds, and pick the most recent one. Documentation is in the Devo 7E/10 user manual. Both Downloads and the user manual are in the menu to the left. This is a new port, and the last changes were fixing bugs with it. The protocol and mixer code is the same as the Tx's with older support and should be fine.
The A7105 will get you the FlySky protocol. Some, but not all, of the Turnigy radio gear uses FlySky. I don't believe there is support for any of the other protocols Turnigy uses. To get FrSky, you'll need to add a CC2500. Probably want to run the nightly build for that as well.
If you run Deviation, it will not only be compatible with Walkera Devo RXXXX, but also the older protocols use by the WK2XXX transmitters. Not that I've ever used any of those. Adding a module - or two, or four - won't change that.
As for using the Walkera Devo Rx's with your other quads - so long as they are just receivers, and don't have any integrated stabilizers, FBL, etc. that can't be turned off, they should work fine. The one that does PPM should also work in PPM mode. But you might ask on a general RC support forum, or in support forums for Walkera or the flight control boards you're using.
04 Jul 2015 04:26 #35078 by FDR
Replied by FDR on topic Devo F12E as a one for all solution.
What the documentation does not mention is that you can't use the Walkera DfuSe uploader and the USB mode with the F12E, but only PB's own uploader software...
Reat through this thread for more info:
www.deviationtx.com/forum/3-feedback-que...-deviation-devo-f12e
04 Jul 2015 04:26 #35079 by Daos
mwm wrote: Let's see:
Thank you so much for your response, this really puzzled me out and as much as I searched I didn't seem to find accurate information.
I will try deviation on my F12E when I receive it, I'll let you know ;)
04 Jul 2015 04:36 - 04 Jul 2015 04:43 #35080 by Daos
So what you mean is that there is no turning back?
Ok I have read the whole thread I will keep reading the manuals and other information so I don't mess it up hehehe thanks
Last edit: 04 Jul 2015 04:43 by Daos.
04 Jul 2015 13:26 #35095 by PhracturedBlue
Replied by PhracturedBlue on topic Devo F12E as a one for all solution.
You CAN go back to the stock firmware on the F12E. You can use either the deviation-uploader or the stock uploader to go back. You can only use my 'deviation-uploader' to install deviation on the F12E though.
Time to create page: 0.410 seconds
