Question on the packet ack on nRF24L01+ module
10 Jul 2015 04:47 #35294 by nkkim91
I'm developing a transmitter using Arduino nano with nRF24L01+ which is targeting for my CX-30.
Merged the yd717_nrf24l01.c file in the src/protocol and nrf24l01.c file in src/protocol/spi to support only CX-30.
However, one problem I faced is the packet_ack() always returns "PKT_TIMEOUT" though I used the same setup/configuration in yd717_init() function.
When I checked the status register, it always returned 0x0E or 0x1E. bit 5 (NRF24L01_07_TX_DS) is never set in any case after sending packet.
So, wondering what is the wrong approach of me ? Would you comment on it if you have experienced the same ?
Thanks,
NamKyu
10 Jul 2015 05:16 #35296 by nkkim91
Found a link of the same issue and the comment saying the CE might be not set correctly.
However, my code set and clear the CE pin connected to a digital pin of Arduino. but, since it's for one target(CX-30), not support multimode, do I need a null function instead of setting/clearing the CE pin ?
devzone.nordicsemi.com/question/662/nrf24l01-does-not-transmit/
* protocol/spi/nrf24l01.c file
static void CE_lo()
#if HAS_MULTIMOD_SUPPORT
PROTOCOL_SetSwitch(NRF24L01);
#endif
static void CE_hi()
u8 en = SPI_ProtoGetPinConfig(NRF24L01, ENABLED_PIN);
u8 csn = SPI_ProtoGetPinConfig(NRF24L01, CSN_PIN);
SPI_ConfigSwitch(en | 0x0f, en | (0x0f ^ csn));
#endif
* my code
static void CE_lo()
digitalWrite(nNRF24L01_CEPin, LOW);
static void CE_hi()
digitalWrite(nNRF24L01_CEPin, HIGH);
Thanks,
Alex
10 Jul 2015 05:45 #35297 by Durete
I'm not developer, but check this thread:
deviationtx.com/forum/protocol-developme...they?start=180#35188
And the articles talking about the ACK bit inverted on nRF24L01+ counterfeit modules.
I guess this could be related with your issue.
10 Jul 2015 09:12 #35302 by nkkim91
Thank you for pointing me to the links !!
I bought 20 pcs of the module through Ali and it was less than $1 in each. I guess it might be a cloned IC, not a genuine.
OK, let me check this out.
25 Sep 2015 20:29 - 25 Sep 2015 20:31 #38063 by jackwu
Hi NamKyu,
I'm so glad to see someone else having done this, and I was wondering if I could learn from your experience! I'm trying to do basically the same thing - transmitting controls to my CX-30 with the nRF24L01+ connected to an Arduino Nano clone, using the phracturedblue Bitbucket code.
How did you port the code onto the Arduino? The jd717_nrf24l01.c isn't in the format of the Arduino IDE and doesn't compile for me when I put it in there, since it doesn't have void setup and void loop functions... and it calls on a lot of headers and sub-headers which I tried to manually add each one. Is it some kind of batch project file that I can import? What am I missing?
It seems you have a lot more experience than me! Please help! Thanks so much!
Best,
Jack
Last edit: 25 Sep 2015 20:31 by jackwu.
Time to create page: 0.393 seconds
