Problems with Devo 7e
20 Jul 2015 11:45 - 20 Jul 2015 11:56 #35667 by DoubleQuad
Problems with Devo 7e was created by DoubleQuad
I got my receiver today - an OrangeRx.
I have it plugged in to use CPPM and my FC (Naze32) is configured to use CPPM.
Issue 1:
I managed to get the receiver bound OK, but in Baseflight, I get no response from the controls when I move them. I have verified that the receiver is bound by turning off the controller and the light on the receiver starts flashing then stops when I turn it back on.
Issue 2:
I went into Channel Monitor in the Transmitter menu and I see that my left stick shows -100 at dead bottom and that figure increases as I push the stick up, but when the stick gets to the vertical middle the figure jumps back to -100 and stays there as the stick moves from middle to dead top.
Issue 3:
It seems that I have to re-bind every time I have powered off my quad. :(
Any help with any of those would be appreciated :)
Last edit: 20 Jul 2015 11:56 by DoubleQuad.
20 Jul 2015 12:53 #35672 by robca
Replied by robca on topic Problems with Devo 7e
Did you calibrate your 7e? that could explain 2
What model of the Orange Rx receiver do you use?
20 Jul 2015 15:10 - 20 Jul 2015 15:21 #35679 by aMax
Replied by aMax on topic Problems with Devo 7e
You did not use the bind plug AND a fixed ID at the Devo....
Edit: To set up all things but the esc, a four cell NMhi bat at the receiver or the fc is quite usefull, e.g rx stick range or modes....
Last edit: 20 Jul 2015 15:21 by aMax.
20 Jul 2015 15:49 #35680 by Cereal_Killer
Replied by Cereal_Killer on topic Problems with Devo 7e
What EXACT OrangeRX?
20 Jul 2015 18:19 #35690 by DoubleQuad
Replied by DoubleQuad on topic Problems with Devo 7e
robca wrote: Did you calibrate your 7e? that could explain 2
Hi yes I did indeed. I did that before I noticed the problem so not sure if it was OK before that our not. But after noticing it I have calibrated 2 or 3 times.
20 Jul 2015 18:22 #35692 by DoubleQuad
aMax wrote: You did not use the bind plug AND a fixed ID at the Devo....
I believe I did as fixed ID is the default isn't it? I didn't change that but will check...
I did my initial bind with the battery plugged strict into my Rx. :)
20 Jul 2015 18:23 #35693 by DoubleQuad
Cereal_Killer wrote: What EXACT OrangeRX?
*sigh* I knew I'd leave something out...
It's an R615x :)
20 Jul 2015 18:45 #35694 by aMax
With this rx and a devo7e, all channels (1-4) should show up at 1520 for neutral on the gui.
20 Jul 2015 19:46 #35698 by DoubleQuad
Hi all,
I have fixed issues 1 and 3 :woohoo:
I still have the issue with my throttle stick that returns to -100 at center and remains at that. I have recalibrated.
Now that I think about it, I know it used to work because the display on the screen used to show it going from -100 to +100, so I have done something to make it not work any more!!
20 Jul 2015 20:23 - 20 Jul 2015 20:32 #35701 by DoubleQuad
I'm thinking that if the calibration data is stored in the tx.INI I might just reset it in there...
Last edit: 20 Jul 2015 20:32 by DoubleQuad.
20 Jul 2015 21:05 #35702 by Arakon
Replied by Arakon on topic Problems with Devo 7e
Make sure you didn't accidently set up a mixer or expo that only goes from -100 to 0 or something.
20 Jul 2015 21:29 - 20 Jul 2015 21:30 #35703 by DoubleQuad
Arakon wrote: Make sure you didn't accidently set up a mixer or expo that only goes from -100 to 0 or something.
Aha! It most likely is something like that. I loaded up another "blank" model and the stick has reverted to showing from -100 to 100.
For a 250 class quad what is a good base model to use?
Last edit: 20 Jul 2015 21:30 by DoubleQuad.
21 Jul 2015 03:16 #35716 by brew99
Replied by brew99 on topic Problems with Devo 7e
You don't need anything fancy as most of the set-up should be adjusted in the FC. Just set-up the four simple channels, and also channel 5 and 6 for switches (AUX1 and 2). After you have the basics communicating, then you can do sub-trims to get your min/max
21 Jul 2015 03:26 #35718 by DoubleQuad
brew99 wrote: You don't need anything fancy as most of the set-up should be adjusted in the FC. Just set-up the four simple channels, and also channel 5 and 6 for switches (AUX1 and 2). After you have the basics communicating, then you can do sub-trims to get your min/max
That's the kind of answer I like to see!! :woohoo:
Thanks man!
21 Jul 2015 19:36 #35750 by DoubleQuad
So it turns out that the problem was that either I, or one of the models I had loaded, had set the safe value which was limiting the values from the Tx.
So I simply reset that and I was away!
But then I hit an issue where I couldn't get the Naze32 to arm, even though I was arming via a switch. Turns out it still won't arm if your end throttle point is too low. I found a post where the dude had to raise his up to 1175 to get his to arm, so I tried that (and a few lower values too) and hey presto! Now I have a quad that flies...
Thanks for all your help guys :)
12 Jan 2017 22:44 #57861 by Jcnube66
Replied by Jcnube66 on topic Problems with Devo 7e
I know that I am posting on an old topic but I just built my first multirotor and i have done almost everything that has already been mentioned. But I cant even see my switches on CLEANFLIGHT when i switch them up and down to assign them. And i also forgot to back up anything off my tx before i flashe the deviation firmware to it. Any thoughts?
Time to create page: 0.610 seconds
