Devo 7E sticky gimbal?
22 Aug 2015 03:32 #37123 by barees63
Devo 7E sticky gimbal? was created by barees63
I hope this isn't too far off topic, but I have a modded Devo 7E running deviationtx (NRF24L01 with A7105 coming) and I'm loving it, but one thing I'm noticing is the left hand gimbal is sticking a bit in horizontal movement (hard to make small smooth movements), just wondering if anyone else has experienced this and what you did about it? I'm thinking of spraying some silicone lubricant on it but thought I'd ask first :P
22 Aug 2015 04:34 #37124 by Cereal_Killer
Replied by Cereal_Killer on topic Devo 7E sticky gimbal?
IMO any type of lubricant should be absolute last resort!
First thing to do is open it up and check the spring tension, then CLEAN any oil / grease OFF with alcohol and try again BEFORE going the lube route.
22 Aug 2015 04:35 - 22 Aug 2015 05:00 #37125 by barees63
Replied by barees63 on topic Devo 7E sticky gimbal?
Even as we speak I am taking the back off to check that out :)
[Edit] After fiddling with the tension screw it feels a lot better
Last edit: 22 Aug 2015 05:00 by barees63.
Time to create page: 0.096 seconds
