Configuring Devo RX601 with CC3D and cleanflight
04 Sep 2015 03:42 - 04 Sep 2015 03:45 #37422 by 187
Hi guys,
I have finished building a 200 quad with 1806 motors and 5" props on 3s and very keen to test it.
Having an issue matching the channels from the RX601 to my DEVO 7e.
I have tried working from all the templates in my 7E
When I am in cleanflight receiver settings, it is showing me that my throttle, aileron, elevator etc. on my receiver aren't matched to the transmitter.
I do get movement when moving the transmitter, but I can't match the throttle movement, to throttle on cleanflight etc. it will show up as pitch or aux1 or whatever depending on the mixer.
Can someone help an inexperienced user get this the right way around?
edit: in the 2nd attachment, there is settings for serial receiver provider, maybe this isn't set right? I've tried pretty much all of them
Last edit: 04 Sep 2015 03:45 by 187.
04 Sep 2015 09:31 #37430 by 187
Ok I got passed that issue, I just swapped the wires on the receiver around.
The main issue was that the sticks on the transmitter needed calibrating, I may have forgotten to do min and max yaw last calibration by rushing.
I am trying to reach the correct mins and maxs now.
Everything is moving what it should, but it isn't reaching far enough to actually arm by the looks of things.
I read in the cleanflight manual 1500 should be neutral and it should reach 1000 and 2000 so I am going to try and achieve this now and see what happens.
04 Sep 2015 09:44 - 04 Sep 2015 09:47 #37432 by aMax
Extend the scale for these channels to both sides on your Devo Mixersetup. If it comes close enough, it will be ok. No way to hit exactly the values.with the 7e. For midrc you will have something like 1497 or 1502........
This should be set in CF for "midrc".
Last edit: 04 Sep 2015 09:47 by aMax.
04 Sep 2015 12:32 #37439 by 187
Thanks,
Can get it to arm now.
Testing it with the props off it seems fine.
04 Sep 2015 13:42 #37442 by aMax
Ok.
For further informations, this will be the best place to go....
www.rcgroups.com/forums/showthread.php?t=2249574
04 Sep 2015 22:56 #37451 by 187
nice link,
heaps of relevant information.
I am going to start reading now, thanks for the advice again.
Nick
Time to create page: 0.098 seconds
